[Geoserver-devel] Security Decorator Issue
I had problems using app-schema plugin with a security authorization module
I have written (using ResourceAccessManager).
I did some debugging and came to code that did some strange casting using
/org.geotools.data.DataStore/.
Author of code is Andrea Aime and I am wondering if someone can review that
part of code.
*org.geoserver.security.decorators.SecuredDataStoreInfo*
method: DataStore getDataStore(ProgressListener listener)
this method does return with following cast:
/return (DataStore) SecuredObjects.secure(ds, policy);/
But there are situations when secure() returns DataAccess that can not be
cast to DataStore.
What I did is I changed return type of getDataStore to DataAccess. That
solved my problem.
/DataAccess /is also return type of super /DecoratingStoreStoreInfo/ class
that /SecureDataStoreInfo /extends.
Configuration that I am using:
GeoServer 2.5.2 with app-schema extension.
Code is somehow complex (casting and generics), so suggestions are highly
appreciated.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Security-Decorator-Issue-tp5185447.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
On Wed, Feb 4, 2015 at 1:00 PM, uros <uros.mesaric-kunst@anonymised.com>
wrote:
part of code.
cast to DataStore.
solved my problem.
I believe you're the first one to use app-schema and the security subsystem
at the same time...
congratulations :slight_smile:
The change you're proposing seems reasonable, can you make a pull request,
on GitHub and
for the master branch, for it?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thank you for your answer.
I hoped that I am doing something wrong :slight_smile:
I found another issue with ModificationProxy that doesn't work with security
wrapped objects (e.g. SecuredLayerInfo for LayerInfo). I found this causing
problems with group layer creation (probably not just there).
I will try to replicate issues in unit tests and than do a fix.
I also have to check process of committing changes to VCS.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Security-Decorator-Issue-tp5185447p5185653.html
On Thu, Feb 5, 2015 at 9:23 AM, uros <uros.mesaric-kunst@anonymised.com>
security
We have a small guide here:
https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md
Ing. Andrea Aime
@geowolf
Technical Lead
