Christian,
I made two pom changes so 2.2.x will build with Maven 3. The current extension/security/pom.xml and extension/security/sec-cas/pom.xml would only build with Maven 2.
Firstly, there were two stray 2.3-SNAPSHOT versions in extension/security/pom.xml; now fixed (2.2-SNAPSHOT), no problem.
Secondly, Maven 3 refused to accept extension/security/sec-cas/pom.xml having security/pom.xml as a parent without a relativePath as on master, so I have added this. Apologies in advance if I have misunderstood your intent or broken anything.
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Hi Ben,
First, Justin did this setup but if the build works, no problem. I cannot check since my 2.2.x build using maven 3 always stops with an error caused by the WCS 1.1 module. On master, everything works fine.
2012/10/15 Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Christian,
Kind regards,
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Don’t let slow site performance ruin your business. Deploy New Relic APM
Deploy New Relic app performance management and know exactly
what is happening inside your Ruby, Python, PHP, Java, and .NET app
Try New Relic at no cost today and get our sweet Data Nerd shirt too!
http://p.sf.net/sfu/newrelic-dev2dev
Geoserver-devel mailing list
Thanks for the fixes Ben. They sound good.
On Mon, Oct 15, 2012 at 3:58 AM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
Hi Ben,
Christian,
Kind regards,
Software Engineer
Justin Deoliveira
OpenGeo - http://opengeo.org
