On Sun, May 31, 2015 at 4:41 PM, Christian Mueller <
christian.mueller@anonymised.com> wrote:
Hi all
I noticed that the file
https://github.com/geoserver/geoserver/blob/master/src/main/src/test/java/org/geoserver/data/test/security.zip
contains 2 files for speeding up the tests.
geoserver.jceks
masterpw.digest
This is nice but it breaks a lot of tests if IBM Java is used. Tests for
the restconfig module produce
Tests run: 354, Failures: 91, Errors: 215, Skipped: 3
Unfortunately, IBM Java cannot handle keystores created by Oracle/Sun. (I
have no idea why, but the keystore implementations have no source code
attached, finding the problem is not an easy job ).
Without this two files the test setup generates a master password and a
keystore containing some keys.
Two possibilities:
1) remove those files
Will it slow down again the build?
2) Add special files geoserver.jceks.oracle and geoserver.jceks.ibm,
during test setup use the correct version depending on the ""java.version" system
property.
I'd go for this one, the build times are barely bearable right now (12
minutes is still a lot, but before the speedups, it was almost 18)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
