[Geoserver-devel] Seperate label and graphic in textsymbolizer
Hello,
I’m trying to separate the label (text) with the graphic component both written in .
However they seem to be overlapped all the time with the graphic at the center of the text.
Does anyone know how to do that?
BTW, I know the fact that we can use to draw graphic but for my case it has other problems.
Thanks in advance,
Yi
Hi Yi,
I was not aware that a graphic was supported inside of a TextSymbolizer... however, have you tried using the "LabelPlacement" element inside of the TextSymbolizer?
-Justin
ps. This query is probably better made on the users list, you will get a better response there.
Yi Wang wrote:
Hello,
I'm trying to separate the label (text) with the graphic component both written in <TextSymbolizer>.
BTW, I know the fact that we can use <PointSymbolizer> to draw graphic but for my case it has other problems.
Thanks in advance,
Yi
!DSPAM:4007,48517256178114901796417!
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
