[Geoserver-devel] Server restart required to register LDAP roles
I was testing out the GeoServer Authentication with LDAP tutorial, and ran into this issue.
After Step 5 of Map LDAP groups to GeoServer roles , the users with administrative roles (e.g. bill) do not behave as administrators, but rather as regular users.
Once restarting GeoServer, the users with administrative roles behave as administrators, as expected.
Reported as https://osgeo-org.atlassian.net/browse/GEOS-7936
I am not quite sure if this a documentation error with the tutorial, or a regression in the LDAP security settings. If anyone with more experience using the LDAP provider knows which of these is more likely, your knowledge would be appreciated.
Note that I was able to reproduce this issue with GeoServer 2.8.3 as well.
Torben
Hi Torben,
It looks more like a regression. For sure it is not the intended behaviour.
Mauro Bartolomeoli
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via di Montramito 3/A
Hi Torben,
I looked a little bit more into the issue you reported.
It seems to work as expected to me. Going to explain: you can give admin rights to users coming from LDAP in two ways:
  1. using the LDAP Authentication Provider only, and filling the groups section as explained here: http://docs.geoserver.org/latest/en/user/security/tutorials/ldap/index.html#map-ldap-groups-to-geoserver-roles; a role service is not needed for this.
After doing that, bill can log in with admin rights (I was able to do that on a fresh 2.10.1 installation). Question: did you login with bill credentials before mapping the groups (then you could experience caching issues)?
  1. creating an LDAP role service as explained here: http://docs.geoserver.org/latest/en/user/security/tutorials/ldap/index.html#configure-the-ldap-role-service
    and setting that role service as the active one (this is not mentioned in the tutorial, where the role service is created, but not really enabled for active usage); the purpose of the tutorial was to enable seeing roles from LDAP in the authorizations sections (data / services), not enabling the role service for role binding; we can probably add a sentence or two in the tutorial to clarify this
Mauro Bartolomeoli
2017-01-19 1:56 GMT+01:00 Torben Barsballe <tbarsballe@anonymised.com>:
Torben
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Hi Mauro,
I used the 1st method. I may have logged in with bill’s credentials before setting the groups once, but when I tested a second time on a clean install I did not, and still saw the same caching issue. I wonder if this is browser or system specific (I was testing on Chrome / Mac OS X 10.12)
Torben
On Wed, Jan 25, 2017 at 1:40 AM, Mauro Bartolomeoli <maurobartolomeoli@anonymised.com.403…> wrote:
Hi Torben,
Mauro Bartolomeoli
2017-01-19 1:56 GMT+01:00 Torben Barsballe <tbarsballe@…3839…>:
Torben
Geoserver-devel@anonymised.comrge.net
