While working on GEOS-6010 I’ve taken a look at the XStreamServiceLoader and ServiceFactoryExtension classes and their children.
It seems like the two overlap in their ability to create new ServiceInfo objects.
XStreamServiceLoader and its subclasses are replacing a bunch of nulls with default values when deserializing. If those properties should be non-null, then it seems like they should be set to their defaults when a new service is created as well as when being deserialized.
Am I missing something about why it’s set up like this or is this just a case of someone reinventing the wheel?
Kevin Smith
Junior Software Developer, OpenGeo
<ksmith@anonymised.com>
I have the feeling that that approach was taken before XStream supported the readResolve() initialization.
A pattern I used sometimes for xstream classes is like this:
public class ModelObject{
public ModelObject(){
readResolve();
private Object readResolve(){
//initialize instance variables to default values…
return this;
Kevin Smith
How ServiceNow helps IT people transform IT departments:
- Consolidate legacy IT systems to a single system of record for IT
- Standardize and globalize service processes across IT
- Implement zero-touch automation to replace manual, redundant tasks
http://pubads.g.doubleclick.net/gampad/clk?id=51271111&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Gabriel Roldan
OpenGeo - http://opengeo.org
Yeah, this is a pain with xstream and that it doesn’t use a default constructor when creating an object. As gabriel says i think the only way to centralize that logic would be in readResolve(). Probably never became a big issue because I don’t believe the ServiceFactoryExtension is used all that much?
On Tue, Sep 10, 2013 at 8:20 AM, Gabriel Roldan <groldan@anonymised.com> wrote:
readResolve();
return this;
Justin Deoliveira
Kevin Smith
Gabriel Roldan
For now I’ve just set the initial value of the interpolation property to Nearest in WMSInfoImpl and that was enough to get my fix for 6010 to pass the unit tests.
Neither factory method seems to be used much.
org.geoserver.config.util.XStreamServiceLoader.create(GeoServer)
is called by
org.geoserver.data.test.SystemTestData.addService(Class, String, GeoServer)
org.geoserver.jdbcconfig.JDBCGeoServerLoader.loadGeoServer(GeoServer, XStreamPersister)
while
is called by
org.geoserver.config.impl.GeoServerFactoryImpl.create(Class)
On 10 September 2013 19:56, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Kevin Smith
readResolve();
return this;
Justin Deoliveira
Kevin Smith
Gabriel Roldan
