[Geoserver-devel] service.properties or services.properties
Today I tried to write a test case using service / role associations and found the following.
The data access object uses “services.properties”. Code is here
https://svn.codehaus.org/geoserver/trunk/src/main/src/main/java/org/geoserver/security/impl/ServiceAccessRuleDAO.java
But the release directory has a file service.properties
https://svn.codehaus.org/geoserver/trunk/data/release/security/
I am quite confused here. Which one is correct ?
I assume “services.properties”, otherwise role assignment would not work.
Christian
Odd indeed. Regardless it does seem services.properties is the one, at least that is what seems to be written out when rules are added.
On Sat, May 19, 2012 at 6:45 AM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
Christian
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
