Hi lists,
first of all, sorry for cross posting.
Could we select an unique commonly used remote repo where to deploy maven artifacts?
Refractions 2 still go down, sometimes.
Therefore, in the past, someone proposed to set a new repo (OSGeo) where to deploy artifacts.
However, as Justin reported some months ago, the OSGeo server bombs out quite often and therefore the GeoServer nightly build is deploying artifacts on a new additional maven repository, hosted by OpenGeo.
However, it seems that the geotools root pom hosted at the OSGgeo repo seems pointing against the refractions repo. Therefore some recent updates seem missing. (http://download.osgeo.org/webdav/geotools/org/geotools/geotools/2.5-SNAPSHOT/geotools-2.5-SNAPSHOT.pom)
Can we move to a single unified repo? Any news about the OSGeo deploying issues? (http://trac.osgeo.org/osgeo/ticket/344)
In case this has been fixed, can you update the automatic build scripts to work against the OSGeo one (in order to updates artifacts and poms)?
In case OSGeo still have problems, is the OpenGeo repo the most valuable one to be used? (In that case, can you provide me the distribution management tag (URL) to be used to deploy our imageio-ext artifacts on it?)
I guess we need to update these things since there is a bit of confusion about which project relies on which repo and which repo is up to date.
Please, let me know.
Best Regards,
Daniele
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
