Hi Ben,
I've been setting up an app-schema config on trunk and fixed a couple issues that prevented it from working and being configured through the UI due to the use of DataStore* instead of DataAccess.
Also, I wanted to repeat that the feature chaining stuff is just great. I managed to set up the MappedFeature config as well as the config for the schema I'm playing with. Also applied the patch at http://jira.codehaus.org/browse/GEOT-2474 locally and it solves the encoding of gml:name.
Yet, I ran desperate on a couple issues regarding gml encoding and hope may be you have some clues:
- simple attributes are not being encoded though they are present in the Feature instances
- I couldn't get one of the nested complex attribtues, which is multivalued, to be encoded more than once.
If you would be so kind to take a look at the config and see if there's something obvious for you that makes this happen I'll be glad of sending you the data config directory.
Best regards,
\Gabriel
Gabriel Roldan
OpenGeo - http://opengeo.org
