I am trying to setup geoserver in eclipse, but I have a few question / issues,
- Is each directory in Geoserver is an eclipse project or not?
- Is each sub-directory of an Directory an eclipse project or not?
It looks like each subdirectory is a seperate spring plugin
and then there is community, it looks like those things are spring plugins as well
Seems like I was being dumb since there is an eclipseAll target in the geoserver project... So that helps out a bit with my questions.
Thanks
Jody Garnett wrote:
Clint Lewis wrote:
Hi Everyone,
This is what I am trying to do:
Is it safe to make the assumption that all .project file in the geoserver project is an eclipse project after running the eclipseAll target?
Also another question, in eclipse, what import option do I use? Do I use "Import Existing project into workspace"
Clint
Jody Garnett wrote:
Clint Lewis wrote:
Hi Everyone,
Ok so I have answered my own question again, You do choose "Import Existing project into workspace" from the root and it will scan all sub-directories and pick up all the projects..
Clint
Clint Lewis wrote:
Clint
Jody Garnett wrote:
Clint Lewis wrote:
Hi Everyone,
