[Geoserver-devel] Severe issue on DataStoreFileController
Dear all,
while testing REST upload of resources against a PostGIS DataStore I faced on a quite severe issue on DataStoreFileController.
If you look at the code workflow, in the unlucky case you would like to add a shapefile to a datastore, this methods either fails if the shapefile is not the first file on the target folder or reloads the whole directory into the database. The biggest issue is that there’s no way to force a cleanup of this directory, named like the datasotre, thus ending up reloading also very old shapefiles.
How exactly this method is ment to be used? What the use case for its implementation? It would be possible at least to add an option to take into account just the files I’m uploading instead of forcing me to reload the whole directory?
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
Hi Alessio,
looking at the mail I have a hint of what you’re talking about, but it would be useful to add some details to
understand where to look into.
What exact REST request are you running? (important as there are several ways to create a store, like,
I would believe that pointing the code to a existing folder is not the same as uploading a zip file, and so on).
Also, is the issue happening on 2.12, and is it unique to it? (since the REST API has been rewritten there)
On Tue, Oct 10, 2017 at 3:53 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Dear all,
Alessio Fabiani
@alfa7691
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Hi Andrea,
currently I tested only version 2.12.x, but I guess the same happens on 2.11 and 2.13.
Cannot say if that worked before. I noticed this behavior while trying to update the GeoServer version for GeoNode from 2.10 to 2.12. On GeoNode there were no changes on the REST calls, and we never faced such issue previously. Therefore I’m guessing it is something new.
Currently I did debug of the code step by step and tried almost all combinations, but at this stage there is no way to add just one shapefile to a DB DataStore without modifying the code. If I correctly interpreted the logic, I guess it must be deeply revised. There something very strange on the way the workflow is managed on this use case.
On Wed, Oct 11, 2017 at 6:13 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Alessio,
Alessio Fabiani
@alfa7691
On Tue, Oct 10, 2017 at 3:53 PM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Dear all,
Alessio Fabiani
@alfa7691
Geoserver-devel@anonymised.comrge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
In particular:
here
https://github.com/geoserver/geoserver/blob/master/src/restconfig/src/main/java/org/geoserver/rest/catalog/AbstractStoreUploadController.java#L109
ZIP file containing the shapefiles are extracted on a folder named $GEOSERVER_DATA_DIR\data{$workspace}{$store_name} without actually removing the old ones, but only checking for old ZIP files with the same name
here
https://github.com/geoserver/geoserver/blob/master/src/restconfig/src/main/java/org/geoserver/rest/catalog/AbstractStoreUploadController.java#L114
becomes the Directory, since a ShapefileDirectoryDataStore is created. however the uploadedFile will never becomes null
here
https://github.com/geoserver/geoserver/blob/master/src/restconfig/src/main/java/org/geoserver/rest/catalog/AbstractStoreUploadController.java#L130
nevertheless “files” already contains the correct list of shapefiles (and ancillary files) I uploaded, those are cleared and replace with uploadedFile which is now the directory containing all data uploaded until now
here
https://github.com/geoserver/geoserver/blob/master/src/restconfig/src/main/java/org/geoserver/rest/catalog/DataStoreFileController.java#L232
the folder is returned and the ShapefileDataStoreFactory created
finally here
https://github.com/geoserver/geoserver/blob/master/src/restconfig/src/main/java/org/geoserver/rest/catalog/DataStoreFileController.java#L416
for a reason that I really could not understand, unless the parameter configure is equal “all” (meaning that I want everything to be configured again), it configures just the first featureTypeName of the list.
But even worse, previously
https://github.com/geoserver/geoserver/blob/master/src/restconfig/src/main/java/org/geoserver/rest/catalog/DataStoreFileController.java#L348
it reloads ALL the tables on the DB. Such method may be potentially dangerous when this folder contains hundreds of uploaded shapefiles and/or very huge ones.
On Wed, Oct 11, 2017 at 6:20 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hi Andrea,
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
Hi Alessio,
On Tue, Oct 10, 2017 at 3:53 PM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Dear all,
Alessio Fabiani
@alfa7691
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
I no one is working on this I can spend some time to do a PR.
Maybe if we can just share few ideas on possible solutions so I can move on the right direction.
Most of the fixes should be quite straight.
On Wed, Oct 11, 2017 at 7:10 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
In particular:
here
here
here
here
finally here
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
On Wed, Oct 11, 2017 at 6:20 PM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Hi Andrea,
Alessio Fabiani
@alfa7691
On Wed, Oct 11, 2017 at 6:13 PM, Andrea Aime <andrea.aime@anonymised.com268…> wrote:
Hi Alessio,
On Tue, Oct 10, 2017 at 3:53 PM, Alessio Fabiani <alessio.fabiani@anonymised.com22…it> wrote:
Dear all,
Alessio Fabiani
@alfa7691
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
https://github.com/geoserver/geoserver/pull/2592
On Thu, Oct 12, 2017 at 3:06 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
On Wed, Oct 11, 2017 at 7:10 PM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
In particular:
here
here
here
here
finally here
Alessio Fabiani
@alfa7691
On Wed, Oct 11, 2017 at 6:20 PM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Hi Andrea,
Alessio Fabiani
@alfa7691
Hi Alessio,
Dear all,
Alessio Fabiani
@alfa7691
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Dear all,
sorry to bother you again on this topic.
After a deeper inspection of the code and spending a lot of time comparing changes between 2.10/11 and 2.12/13 versions of GeoServer, I finally identified the real issue here.
Trying to summarize (if something is not clear please let me know), currently the upload POST of zip file to RESTConfig DataStore is affected by an important issue which wasn’t present on previous versions of GeoServer.
Basically in the case you want to add files to a DataStore allowing more than one FeatureType, like as an instance a DB DataStore, the code currently leave old files into the datastore folder with two side-effects:
  1. Even if you delete a Layer/FeatureType from the DataStore from the source store (let’s say a table on the DB), it will be created again at the next POST since the code will find old source files on the upload folder.
  2. We don’t have control anymore on which Features are automatically configured via REST since the code has only two options: a) configure the first one in alphabetical order b) configure all of them (even the deleted/old ones)
Long story short, the origin of this issue is due to this change:
https://github.com/geoserver/geoserver/blob/2.11.x/src/rest/src/main/java/org/geoserver/rest/util/IOUtils.java#L786
this small check has been removed from IOUtils since 2.12.x, but it was important in order to identify the files to be refreshed/cleared out after the upload, other than the .zip file.
Now, I’m asking here if someone is aware of a specific reason to remove this check. If not I would propose to restore this line of code instead of trying to understand and modify the whole DataStoreRESTController workflow. An action must be taken anyway soon, since currently we have an important regression on GeoServer code.
Thanks for you patience and please let me know your thoughts.
On Thu, Oct 12, 2017 at 4:34 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
On Thu, Oct 12, 2017 at 3:06 PM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Alessio Fabiani
@alfa7691
On Wed, Oct 11, 2017 at 7:10 PM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
In particular:
here
here
here
here
finally here
Alessio Fabiani
@alfa7691
Hi Andrea,
Alessio Fabiani
@alfa7691
Hi Alessio,
Dear all,
Alessio Fabiani
@alfa7691
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Sorry again :slight_smile:
Just to be clear this line
boolean saveFile = files != null && request!=null && request.getMethod().equals(Method.POST);
is the correct one, not the issue. That line of code was present on 2.11 and before and has been removed since 2.12.
Sorry for the confusion.
On Tue, Oct 31, 2017 at 10:08 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Dear all,
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
On Thu, Oct 12, 2017 at 4:34 PM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Alessio Fabiani
@alfa7691
On Thu, Oct 12, 2017 at 3:06 PM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Alessio Fabiani
@alfa7691
In particular:
here
here
here
here
finally here
Alessio Fabiani
@alfa7691
Hi Andrea,
Alessio Fabiani
@alfa7691
Hi Alessio,
Dear all,
Alessio Fabiani
@alfa7691
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Alessio,
the mass file moves happened during the REST upgrade made it hard to track because
we have had two IOUtils in two separate modules for a week or so, but I believe I’m at fault here,
the inflate code I copied over did not contain saveFile anymore:
https://github.com/geoserver/geoserver/commit/bd898da949c56013ff2239ffce7edcba6bb84966
If I had to guess, that check is “magic”, the caller is unaware of what’s happening and the
comment above it does not explain what’s the logic for it.
So no objection in fixing, maybe with a better explanation of what is going on in the commit, and/or
maybe passing saveFile a parameter from the
caller, where the context may make more evident what the check is about.
On Tue, Oct 31, 2017 at 10:20 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Alessio Fabiani
@alfa7691
On Tue, Oct 31, 2017 at 10:08 AM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Dear all,
Alessio Fabiani
@alfa7691
On Thu, Oct 12, 2017 at 4:34 PM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
In particular:
here
here
here
here
finally here
Alessio Fabiani
@alfa7691
On Wed, Oct 11, 2017 at 6:20 PM, Alessio Fabiani <alessio.fabiani@anonymised.com…4522…it> wrote:
Hi Andrea,
Alessio Fabiani
@alfa7691
Hi Alessio,
Dear all,
Alessio Fabiani
@alfa7691
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Hello Alessio,
I can’t seem to find out exactly where that check was removed either (It seemed to occur right in the middle of a bunch of bulk refactoring), and agree the check should probably be restored.
Torben
On Tue, Oct 31, 2017 at 2:36 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Alessio,
On Tue, Oct 31, 2017 at 10:20 AM, Alessio Fabiani <alessio.fabiani@anonymised.comsolutions.it> wrote:
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Alessio Fabiani
@alfa7691
On Tue, Oct 31, 2017 at 10:08 AM, Alessio Fabiani <alessio.fabiani@anonymised.com.it> wrote:
Dear all,
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
Alessio Fabiani
@alfa7691
On Wed, Oct 11, 2017 at 7:10 PM, Alessio Fabiani <alessio.fabiani@anonymised.com.4522…it> wrote:
In particular:
here
here
here
here
finally here
Alessio Fabiani
@alfa7691
Hi Andrea,
Alessio Fabiani
@alfa7691
Hi Alessio,
Dear all,
Alessio Fabiani
@alfa7691
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
