[Geoserver-devel] Shall we enable JTS overlay NG by default?
it’s been discussed a bit in the past, but not actually done… shall we enable JTS overlay NG
by default, unless there is an explicit setting for that property?
Lately I’ve came across cases where the extra performance and stability are useful.
Draft pull request here:
https://github.com/geoserver/geoserver/pull/7311
We could let this be on the main branch for a while, and it will eventually trickle down to stable and maintenance with the new releases.
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
+1 from me
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ian Turton
+1
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ian Turton
+1
-Jukka Rahkonen-
Lähettäjä: Torben Barsballe <torbenbarsballe@…403…>
Lähetetty: tiistai 5. joulukuuta 2023 20.10
Vastaanottaja: Ian Turton <ijturton@…403…>
Kopio: GeoServer geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] Shall we enable JTS overlay NG by default?
+1
Torben
On Tue, Dec 5, 2023 at 1:10 AM Ian Turton <ijturton@…403…> wrote:
+1 from me
Ian
On Mon, 4 Dec 2023 at 17:51, Andrea Aime <andrea.aime@…6887…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Geoserver-devel mailing list
Ian Turton
