On 26/02/12 17:49, Andrea Aime wrote:
GeoServer web.xml contains a filter whose purpose in life is to change the
html returned by GeoServer to respect the "proxy base url".
However tests show it conflicts with the gzipping filter and besides, as far
as I know the current GUI generates only relative URLs, meaning the
filter is not really needed (see http://jira.codehaus.org/browse/GEOS-4756)
Shall we just remove it? It seems its presence today serves no actual purpose.
Andrea, does this only affect the user interface or other HTML or XML? The reverse proxy base URL is used in app-schema deployments to rewrite absolute URLs (see below).
Kind regards,
Ben.
-------- Original Message --------
Subject: RE: [Geoserver-devel] Shall we remove the reverse proxy filter?
Date: Mon, 27 Feb 2012 11:38:13 +0800
To: Caradoc-Davies, Ben
Hi Ben,
Yes, all DPI/ERDD WxS instances are deployed behind a reverse proxy.
- geology.data.vic.gov.au/services <--> secret-server:8080
This is all a bit rushed and from memory ...
The issue isn't so much with the Geoserver GUI (not exposed externally/of little use with app-schema ... for now) ...
Setting the proxyBaseURL is vital to ensuring valid URLs are provided in responses to various WxS requests.
You're right the DescribeFeatureType is one, for example when a DescribeFeatureType is used as the schemaLocation in place of the canonical schema location.
I'm pretty sure it was also need for resource locations in GetCapabilities responses. Check out the ows:Operation/* elements in this response.
http://geology.data.vic.gov.au/services/earthresourceml/wfs?service=WFS&version=1.1.0&request=GetCapabilities
If memory serves, all of these would be innaccesible to any external client: http://secret-server:8080/earthresourceml/wfs.
Pretty sure a similar thing applies for WMS.
Removing it would be a Bad Thing.
Alistair
-----Original Message-----
Sent: Monday, 27 February 2012 16:16
To: Alistair Ritchie
Subject: Fwd: [Geoserver-devel] Shall we remove the reverse proxy filter?
Alistair,
I have a vague recollection that the reverse proxy filter is necessary for correct functioning of app-schema behind a proxy, as in DPI Vic?
Does this affect HTML such as DescribeFeatureType responses?
Kind regards,
Ben.
Subject: [Geoserver-devel] Shall we remove the reverse proxy filter?
Date: Sun, 26 Feb 2012 17:49:02 +0800
To: Geoserver-devel <geoserver-devel@lists.sourceforge.net>
[Andrea's original message]
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
