[Geoserver-devel] Shape export is empty [Windows Server] [SQLServer]
Hi List,
I have a problem with the Shape-Zip export via WFS.
I can download via WFS request, but the ZIP File is damaged / empty.
EXCEL2007 and SHAPE export format is broken.
GML 2, 3, excel old, csv works.
Any Idea?
It works on a Windows Server 2012 with SQL Server 2012.
I think that the Path Variable for the Temp folder of the Tomcat is wrong, but why works the GML export?
The only error Ifound is this……
But filename and directory is needed for the WMS.
ERROR [gwc.layer] - An error occurred trying to determine if the layer is geometryless
java.lang.RuntimeException: java.io.IOException: The filename, directory name, or volume label syntax is incorrect
Mit freundlichen Grüßen
Im Auftrag
Michael Räder
