All,
I am trying to simply view a shapefile, using the wms, that I’ve loaded into geoserver. I created a new datastore (“scout”) for my shapefile and it says that the data was loaded without incidence. Now, I have to specify a layer in the url for the map image I am trying to create. I have read that this layer name is the FeatureType. So I created a new FeatureType from my “scout” datastore called “scout_arcs”. I clicked on the “bounding box” link and then clicked apply and save. However, my layer is not available. I tried a simple map request through a url specifying “scout_arcs” as the layer name and it says “no such layer on the server”. I also tried checking my getCapabilities and the xml does not list my layer as available. Does anyone know what I might be doing wrong here?
Scott
Scott Pezanowski
email: scottpez@anonymised.com
Does it work on the wfs side of things? Does the wfs getCapabilities
document have the featureType names scout_arcs? Or does it not show up
at all?
Can you set the loggingLevel to FINER and send the logs (catalina.out on
tomcat) ?
Quoting Scott Pezanowski <scottpez@anonymised.com>:
All,
I am trying to simply view a shapefile, using the wms, that I've
loaded into geoserver. I created a new datastore ("scout") for my
FeatureType. So I created a new FeatureType from my "scout" datastore
called "scout_arcs". I clicked on the "bounding box" link and then
simple map request through a url specifying "scout_arcs" as the layer
name and it says "no such layer on the server". I also tried checking
Scott
********************************************* Scott Pezanowski
This SF.Net email is sponsored by: SourceForge.net Broadband
Sign-up now for SourceForge Broadband and get the fastest
6.0/768 connection for only $19.95/mo for the first 3 months!
http://ads.osdn.com/?ad_id=2562&alloc_id=6184&op=click
Geoserver-devel mailing list
This mail sent through IMP: https://webmail.limegroup.com/
