[Geoserver-devel] Sharing some user feedback about managing services per workspace
I’ve been talking a bit with some users that are trying to have a single
GeoServer with several workspaces, one per application/department, each
providing some virtual services.
One grievance they reported is how hard it is to transfer workspace configurations
from test to production enviroments due to the gwc integration, and in particular,
the gwc-layers.
I was wondering, wouldn’t it make sense to keep the gwc-layers folder inside
the workspace, at least for layers/groups that are workspace specific?
Checking, it seems the current design does not make it all that easy,
mostly because it’s keeping everything keyed by tile layer id,
and that information by itself does not provide any clue about the
containing workspace, if any.
I was wondering if anyone else has already investigated this issue?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I like the idea,l of gathering everything by workspace. Difficulties related to configuration portability is a common theme.
On Sat, Mar 12, 2016 at 3:36 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
the gwc-layers.
Ing. Andrea Aime
@geowolf
Technical Lead
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785111&iu=/4140_______________________________________________
Geoserver-devel mailing list
Jody Garnett
Kevin what is your though on this? What affects would it have on the gwc codebase? Or is it just an integration challenge…
On 12 March 2016 at 04:34, Andrea Aime <andrea.aime@anonymised.com> wrote:
the gwc-layers.
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
For what it’s worth a while back we identified this as a gap with virtual services and when I discussed it with Gabriel he definitely agreed we should allow gwc config to be local to a workspace, but that it was far from a trivial effort.
Jody Garnett
the gwc-layers.
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Mar 14, 2016 at 11:36 PM, Justin Deoliveira <jdeolive@anonymised.com>
Yep, that confirms my impression, feasible but not easy
Ing. Andrea Aime
@geowolf
Technical Lead
Yes this definitely sounds like a good idea, and like it would be non-trivial to implement.
I haven’t looked at this particular part of the problem, but I have looked at giving GWC it’s own idea of virtual services that could be hooked up to GeoServer workspaces the same way as GeoServer’s own virtual services. I have a ticket for the issue in the GWC bug tracker here: https://github.com/GeoWebCache/geowebcache/issues/320
Since GWC doesn’t really have workspaces, my thought was to implement it as filters over the complete GWC catalog that could hide or rename layers. (https://github.com/GeoWebCache/geowebcache/issues/319) Alternatively it could be done using the Separate “Configuration” objects in GWC for this, although that would require making a separate one for each workspace in the GWC integration. Before that seems like too much work, but if the back end implementation of the configuration is being divided up by workspace anyway, it might make sense to do it that way.
Kevin Michael Smith
smithkm@anonymised.com
On Wed, Mar 16, 2016, at 11:29 AM, Andrea Aime wrote:
On Mon, Mar 14, 2016 at 11:36 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
