Hello,
I want to develop a geoserver function (or module) that search shortest path
routing in geoserver, haw I must proceed.
Edward
View this message in context: http://www.nabble.com/Shortest-path-in-geoserver-tf4533676.html#a12938192
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
There has been some work done in a module in GeoTools that could be useful, that Justin may be able to tell you more about.
You might also check out pgRouting, and figure out how to make a wrapper around it as a module in GeoServer.
Chris
Achilles wrote:
Hello,
Edward
Yeah, there is a Geotools module that does network and has some routing
code. The problem with it is that is memory bound. pgRouting is
interesting, I saw chris schmidt give an interesting demo of it at
foss4g. However I am not sure how well it scales.
Here are some docs about the geotoosl module:
http://docs.codehaus.org/display/GEOTDOC/Graphs#Graphs-shortestPath
-Justin
Chris
Achilles wrote:
Hello,
shortest path
Edward
!DSPAM:4007,46fe725e228561030819293!
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
