I guess existing tests already cover this? Otherwise, I can add a WFS-specific test.
On Tue, Sep 29, 2015 at 3:58 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
I’d go for the catalog builder (most central place, widely used) and use EPSG:404000 (aka lack of CRS)
On Tue, Sep 29, 2015 at 3:51 PM, Stefano Costa <stefano.costa@anonymised.com8…> wrote:
Dear developers,
a few days ago I opened GEOS-7216: WFS GetCapabilities throws NPE if published layer has no geometry.
As I mentioned in the issue description, there may be situations when a user might legitimately want to publish a geometryless layer (e.g. the GeoSciML’s GeologicEvent feature type). This thread also confirms that should be possible to do so.
Now, if one tries to publish a geometryless layer through the web UI, nothing can go wrong, as the form validation forces the user to define at least a declared SRS and a lat/lon bounding box.
However, through the REST API it is possible to mess things up and publish a layer with no SRS and no lat/lon bounding box, which results in the NPE I reported in the issue.
The simplest fix I can come up with is to set the declared SRS to a default value (EPSG:4326? EPSG:404000?) if none was found; basically this means adding an else block to this if statement in org.geoserver.catalog.CatalogBuilder:
https://github.com/geoserver/geoserver/blob/c8013c078da0c86b9b1e29913a75fabb7f8f9c9a/src/main/src/main/java/org/geoserver/catalog/CatalogBuilder.java#L653
This is enough to ensure that a lat/lon bbox will be computed and so the NPE will not be thrown anymore.
An alternative could be to apply the same logic not in CatalogBuilder (gs-main module), but in the REST resources handling feature types, org.geoserver.catalog.rest.FeatureTypeResource and org.geoserver.catalog.rest.DataStoreFileResource (gs-restconfig module).
Any thoughts?
Best regards,
Stefano Costa
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
