as far as I can tell there is a number of build failures on Travis that are file system related, and others
that might be related to concurrent load in the build environment (just a guess).
Build have just not been very reliable lately.
I was checking our options and found this table:
https://docs.travis-ci.com/user/reference/overview/#Virtualisation-Environment-vs-Operating-System
We are on the container based trusty environment right now. I was wondering, has anyone tried already
the sudo enabled one instead?
As far as I can tell from the table, it would give us more memory, more disk space, a “real” file system
instead of a user space one, at the price of higher startup time and probably less CPU available.
Worth a try, to see if we can get more stable builds?
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
NB: Trying the sudo enabled one is cheap since Travis automatically builds branches*. For GeoMesa, we’ve had various Travis issues, and we fooled around with branches to try out various things. Using the sudo-enabled boxes definitely helped…
After that… we found that tweaking Maven+memory parameters and pulling other tricks helped.
*https://travis-ci.org/geoserver/geoserver/branches
On 06/04/2018 04:56 AM, Nuno Oliveira wrote:
+1
On 06/03/2018 08:00 AM, Andrea Aime wrote:
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Might be worth trying. Two risks are (1) builds timing out because of reduced CPU resources ("bursted" CPU happens only rarely and often much less is available) and dependency download time, and (2) problems installing packages.
Do you know if the Maven repo is still cached on sudo enabled workers?
Kind regards,
Ben.
On 03/06/18 19:00, Andrea Aime wrote:
guess).
disk space, a "real" file system
------------------------------------------------------- *Con riferimento
telephone or e-mail.*
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/>
New Zealand
On Tue, Jun 5, 2018 at 12:52 AM, Ben Caradoc-Davies <ben@anonymised.com>
It's a one liner, let's see how it goes
It should, the caching page makes no mention of sudo:
https://docs.travis-ci.com/user/caching/
