[Geoserver-devel] Show 45 Millions of data : HeatMap or Clustering
Hi everybody,
For my work, I have to be able to propose by wms a representation of 45
million point data (position).
For the moment, I use the Heatmap and Clustering representations, proposed
on different forums, and calculated using the WPS module. Beyond 16 million
features, geoserver no longer responds, or it takes a lot of time.
Do you ever encounter this problem? If so how then? Can I multi-thread
treatments?
Moreover, looking at the logs, I have the impression that geoserver requests
3 times the selection of the elements in database, why?
thank you for everything
View this message in context: http://osgeo-org.1560.x6.nabble.com/Show-45-Millions-of-data-HeatMap-or-Clustering-tp5297803.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
I’m not the author of those processes so I can only provide limited help, but I’m wondering
do you really want to transfer that many points between PostGIS and GeoServer?
I would look for a way to do clustering directly in the database, and get out directly
the synthetic information instead.
Maybe using a SQL view, for example. This stackoverflow entry might be of help:
http://gis.stackexchange.com/questions/11567/spatial-clustering-with-postgis
On Tue, Nov 29, 2016 at 9:52 AM, jarjar <jeoffrey.jardin@anonymised.com> wrote:
Hi everybody,
treatments?
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Jeoffrey,
We have tweaked the heatmap process for use with GeoMesa; the process can be changed to pass query hints which a GeoTools datastore can leverage to execute the query differently. As an example of setting the hints in the process, see [1]. Those query hints are picked up by the GeoMesa query planner, and the computation of the heatmap can be distributed to the Accumulo tablet servers. Instead of returning SimpleFeatures, a grid of inputs to the HeatmapSurface is computed by the DataStore.
Anyhow, I mention that as an example of tweaking a WPS process a little bit; there is some effort at the DataStore level as well… And I’m not sure what could be done in PostGIS; there may be something clever to do there.
As a back-of-the-envelope, for GeoMesa, I’ve typically seen a few hundred thousand records stream back to GeoServer per second. As a gut feeling, I’d say that the optimization for a heatmap speeds things up around 10-25%… Even with that, for a query returning 45 million records, it could take longer than 60 seconds for that many records to come back. The usual rendering timeout is set to 60 seconds, so requests could be dying there.
Jim
  1. https://github.com/locationtech/geomesa/blob/master/geomesa-process/src/main/scala/org/locationtech/geomesa/process/DensityProcess.scala#L115-L123
On 11/29/2016 09:35 AM, Andrea Aime wrote:
Hi everybody,
treatments?
Geoserver-devel@anonymised.comsourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
I'd go one step further than Andrea and ask: Have you considered pre-rendering the data into a raster heatmap representation or otherwise pre-processing into an aggregation of some sort using a standalone GIS/tool? 45 million points is a *lot* of data - hundreds of megabytes on the conservative side.
When datasets get that large, it's usually worthwhile optimising so you're not selecting/using the entire dataset per-query.
Even if the data changes on say, an hourly basis, you could probably automate re-generation using GRASS/GDAL or similar and use GeoServer to serve only the latest edition.
Jonathan
On 29/11/2016 08:52, jarjar wrote:
Hi everybody,
treatments?
