I would be happy with Disposer.
Please mark the FileWatcher thread pool as Daemon in anywise (as that was my intention when writing).
On 4 February 2015 at 12:45, Kevin Smith <ksmith@anonymised.com> wrote:
I’d like to get this fixed soon. Does anyone have a problem with documenting the limitations of the Disposer in terms of guaranteeing the order of destruction? Failing that I’ll go with the Daemon thread approach which fixes the immediate problem and is otherwise no worse than the current way things work, and has been used elsewhere.
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
Geoserver-devel mailing list
Jody Garnett
On 29 January 2015 at 11:32, Kevin Smith <ksmith@anonymised.com> wrote:
Spring doesn’t operate so much on the basis of registering things in an order as looking at the dependencies between bean definitions, then it comes up with an ordering based on that. To get the desired ordering requires that all beans declare that they depend on Disposer. The point of Disposer is to provide something that does work on a ‘register for destruction’ basis, so it might well make sense to have it do that destruction in reverse order of registration.
I’m inclined to go with just making a best effort by having a few major components depend on it, and then document that anything needing guarantees about the order of destruction within the spring context beyond that should be using beans in the spring context rather than Disposer.
Kevin Smith
Software Engineer | Boundless
+1-778-785-7459
@boundlessgeo
On 27 January 2015 at 12:03, Ian Schneider <ischneider@anonymised.com> wrote:
As for ordering, it appears that:
“Based on the initialization order of beans, this same order will be followed in reverse for consistency.”
So registering the Disposer first will ensure it gets called last. If relative order is important (as you note, Kevin), components that require ‘late’ disposal can register w/ the Disposer.
Kevin Smith
+1-778-785-7459
@boundlessgeo
On Tue, Jan 27, 2015 at 12:47 PM, Kevin Smith <ksmith@anonymised.com> wrote:
The only mechanism I can see to force ordering of destruction is to make other beans depend on Disposer. Of course anything in a position to mark itself as depending on Disposer doesn’t need Disposer as it could just be a DisposableBean itself and then dispose of its resources properly. We could make a few significant components depend on Disposer to try to shunt it down the list a reasonable distance and then document that once destruction starts, registered objects might be destroyed at any time, and if that’s not good enough then proper disposal should be used instead.
Ian Schneider
1-877-673-6436
@boundlessgeo
On 27 January 2015 at 00:51, Andrea Aime <andrea.aime@anonymised.com.1268…> wrote:
Kevin Smith
+1-778-785-7459
@boundlessgeo
On Tue, Jan 27, 2015 at 1:33 AM, Kevin Smith <ksmith@anonymised.com> wrote:
Yes, marking the threadpools as Daemon is the really trivial but kludgy way of doing it. The Disposer is the nicer but still a bit of a kludge way which as the benefit of not leaving the threadpools open after doing an undeploy. Making several additional classes Disposable so that they can cascade the disposal properly is the really nice and tidy way that involves a lot of work, and probably can’t be backported.
I did not look in the details, but the assesment of trying to do clean disposing being hard feels right.
The Disposer object is indeed a simpler solution, but it might have a gotcha, what if anything
needs the object being disposed during the shutdown?
Is there any way to make sure the Disposer runs last in the Spring context shutdown order?
Or anything at the servlet specification level?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
