[Geoserver-devel] Significant increase in full build times (app-schema test)
I’ve noticed that the build times jumped up two minutes and a half recently, looking at the build
I’ve found this:
539656 [INFO] Application Schema Integration Test … SUCCESS [03:59 min]
Feature chaining tests seem to be the culprit:
(attachments)
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On 10/12/17 22:41, Andrea Aime wrote:
I've noticed that the build times jumped up two minutes and a half
I've found this:
*539656 [INFO] Application Schema Integration Test ................ SUCCESS
[03:59 min]*
Can you identify the commit that caused the increase?
Wow... my guess is that the test became internet bound, and my ADSL is
making this very evident.
Rings any bell to app-schema experts?
The test infrastructure is designed to run offline, with all the GeoTools test schemas packed into jars (see GeoTools modules/extension/app-schema/app-schema-packages) and the schema resolver infrastructure designed to use these jars even for validation (unless we missed some in later tests). What happens if you run these tests with your network disconnected? ADSL should make no difference. I note that www.geosciml.org is down at the moment, but we use the jars not live resources for tests.
If there are some new tests that use online resources, we can fix the problem by bundling their schemas like those in app-schema-packages.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/&gt;
New Zealand
