[Geoserver-devel] Simplify and uniform test dependencies
one of the things that have been bothering me lately is that test dependency management
in GeoServer is a bit messy:
  • Having to declare the basic dependencies every time they are needed to write a test
  • Use of different libraries, or ad-hoc code while a library would do
  • General lack of uniformity
    I started with this PR, that’s centralizing all basic test dependencies in the main pom, giving all modules a basic set of testing tools that everyone can use with no extra effort:
  • junit and spring-test
  • hamcrest
  • xmlunit for xml testing
  • jsonpath for json testing
  • jsoup for HTML testing
  • awaitility for tests that need to wait for asynch processing (rather than doing fixed waits or hand made wait loops)
    Once that’s in, I’d like to continue by:
  • Removing all Thread.sleep and replace with awaitility, that can poll for a certain condition up to a maximum wait time, but will exit as soon as the condition is met (will go fast on local machines, but wait enough for slow poke github actions)
  • Settle on one mock library and migrate existing tests. I’d suggest going for mockito, it is more alive than easymock, and often easier to use.
  • Upgrade test libraries to latest (little by little)
    Opinions?
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Double checking my maven understanding here, maven test dependencies are not transitive (which is why we ended up with so much duplication), by moving the dependencies to root pom the test scope dependencies are inherited by child modules eliminating all the duplication.
Jody Garnett
In the meantime,
moved lots of tests waiting for conditions to use Awaitility. PR updated: https://github.com/geoserver/geoserver/pull/5919
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Reviewed, love the improvements. As this is a non-functional change (just improving build/test environment) I would like to recommend backporting also.
Something to discuss in tomorrow’s meeting.
Jody Garnett
