[Geoserver-devel] SLD="a new sld file" does not work with the URL
I tried changing the default SLD for the topp:states with a SLD I created ,
but it still displays the default SLD and does not give any error message.I
also tried using mystyles.xml file. The url is as :
http://localhost:8080/geoserver/wms?bbox=-127.61950065,23.7351786,-64.08177035,50.592523400000005&Format=application/openlayers&request=GetMap&layers=topp:states&width=800&height=317&srs=EPSG:4326&SLD=http://localhost:8080/geoserver/styles/mystyle.sld
How can I change the SLD file at runtime , without publishing and restarting
the SLD file on the geoserver. I am using geoserver1.6.3 and also with
1.6.2.
Thanks
View this message in context: http://www.nabble.com/SLD%3D"a-new-sld-file"-does-not-work-with-the-URL-tf4681910.html#a13378766
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Can you include mystyle.sld? I cant be sure but my guess is that the
name of the Layer defined in your SLD does not match the name of the
layer being specified so it is ignored and the default is used.
goeserver developer wrote:
1.6.2.
Thanks
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Its working , as with your corrections.
Justin Deoliveira-4 wrote:
message.I
restarting
1.6.2.
Thanks
Justin Deoliveira
Geoserver-devel mailing list
View this message in context: http://www.nabble.com/SLD%3D"a-new-sld-file"-does-not-work-with-the-URL-tf4681910.html#a13724747
