[Geoserver-devel] sld filter function 'area' returning area in pixels?
Hi Devs,
having a polygon dataset, I want to show small polygons (<1m2) different from the rest of the polygons
I thought to use the 'area' function which according to this:
http://docs.geoserver.org/stable/en/user/filter/function_reference.html
would give:
"The area of the specified geometry. Works in a Cartesian plane, the result will be in the same unit of measure as the geometry coordinates (which also means the results won’t make any sense for geographic data)"
But what I observe here is that it returns the size in pixels, while data is in meters.
Because zooming in I saw the style of some bigger polygons change (while off course the geometry area itself stays the same).
Also showing the area in a label shows that on zooming in the area is changing on every zoomlevel...
QUESTION:
- is this supposed behaviour or is this a bug?
- IS it possible to use the geometry area in filters/labels
Note: Tried both Area and area
Richard Duivenvoorde
PS: example rule below
         <Rule>
         <Name>poly</Name>
         <Title>poly</Title>
         <ogc:Filter>
                 <ogc:PropertyIsGreaterThan>
                     <ogc:Function name="area">
                         <ogc:PropertyName>GEOM</ogc:PropertyName>
                     </ogc:Function>
                     <ogc:Literal>1.0</ogc:Literal>
                </ogc:PropertyIsGreaterThan>
         </ogc:Filter>
         <PolygonSymbolizer>
             <Fill>
                 <CssParameter name="fill">#104DAF</CssParameter>
                 <CssParameter name="fill-opacity">
                     <ogc:Literal>0.4</ogc:Literal>
                 </CssParameter>
             </Fill>
             <Stroke>
                 <CssParameter name="stroke">#104DAF</CssParameter>
                 <CssParameter name="stroke-width">1</CssParameter>
             </Stroke>
         </PolygonSymbolizer>
     <TextSymbolizer>
         <Label>
                     <ogc:Function name="Area">
                     </ogc:Function>
         </Label>
         <Font>
           <CssParameter name="font-family">Arial</CssParameter>
           <CssParameter name="font-size">14</CssParameter>
           <CssParameter name="font-style">normal</CssParameter>
           <CssParameter name="font-weight">bold</CssParameter>
         </Font>
         <LabelPlacement>
           <PointPlacement>
             <AnchorPoint>
               <AnchorPointX>0.5</AnchorPointX>
               <AnchorPointY>0.5</AnchorPointY>
             </AnchorPoint>
           </PointPlacement>
         </LabelPlacement>
         <Fill>
           <CssParameter name="fill">#000000</CssParameter>
         </Fill>
       </TextSymbolizer>
     </Rule>
     <Rule>
         <Name>point</Name>
         <Title>point</Title>
         <ogc:Filter>
                 <ogc:PropertyIsLessThanOrEqualTo>
                     </ogc:Function>
                     <ogc:Literal>1</ogc:Literal>
                </ogc:PropertyIsLessThanOrEqualTo>
         </ogc:Filter>
         <PointSymbolizer>
             <Graphic>
                 <ExternalGraphic>
                     <OnlineResource xlink:type="simple" xlink:href="point.svg" />
                 <Format>image/svg+xml</Format>
              </ExternalGraphic>
             </Graphic>
         </PointSymbolizer>
         <PolygonSymbolizer>
             <Fill>
                 <CssParameter name="fill">#ff0000</CssParameter>
                 </CssParameter>
             </Fill>
             <Stroke>
                 <CssParameter name="stroke">#ff0000</CssParameter>
             </Stroke>
     </Rule>
On Wed, Nov 30, 2016 at 10:51 AM, Richard Duivenvoorde <rdmailings@anonymised.com..>
wrote:
QUESTION:
I don't think it was ever given much of a thought, but I'd classify it as a
bug. One somewhat hard to
fix, geometries are generalized, reprojected and transformed in screen
space "in place" to limit
garbage generation, so the label should be evaluated before that happens.
Fixing that without causing a visible performance regression in normal
rendering might be tricky business, but should be doable.
I'd open a ticket.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I wonder if we could tie the area calculation to UOM? Looks like currently UOM is an attribute on the symbolizer, so not quite in the right place to work with area, but might be something to think about.
In the interim, you may be able to use the wms_scale_denominator environment variable to calculate the proper area from the area in pixels.
Torben
On Wed, Nov 30, 2016 at 2:57 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
On Wed, Nov 30, 2016 at 10:51 AM, Richard Duivenvoorde <rdmailings@anonymised.com> wrote:
QUESTION:
  • is this supposed behaviour or is this a bug?
I don’t think it was ever given much of a thought, but I’d classify it as a bug. One somewhat hard to
fix, geometries are generalized, reprojected and transformed in screen space “in place” to limit
Fixing that without causing a visible performance regression in normal rendering might be tricky business, but should be doable.
I’d open a ticket.
Ing. Andrea Aime
@geowolf
Technical Lead
<http://docs.geoserver.org/2.1.4/user/styling/sld-extensions/uom.html&gt;?
<http://docs.geoserver.org/2.2.4/user/styling/sld-extensions/substitution.html#predefined-variables&gt;
Ah! That is a cool trick. Did not come up on this one, Thanks!
For me it does not have to be very precise, I just want to have some artificial treshold to say "and now it is a point".
So I think if I can pull wms_scale_denominator into my function I'm happy.
Richard
