Hi Andrea,
This proposal is backed up by myself. I want to support the
interoperability between QGIS and GeoTools/GeoServer. I'm also
interested in improving GeoPackage.
Jeff Yutzler (OGC GeoPackage editor) confirms that there are no
interoperable approaches to handle styling in GeoPackage for now, but he
is committed to find a standard approach.
If we go forward with a sound proposal, we can get some more open source
projects adopting our approach regarding "native" styles that can be
delivered with the data. I can contribute with this approach to both
GeoTools and QGIS. It will be even easier to support this in uDig.
If you or the PSC can help me to find additional resources to support
this proposal, that would be very welcome. You comments are already a
valuable contribution. Thanks!
Jorge Gustavo
On 23-03-2018 13:04, Andrea Aime wrote:
just a reminder, the original motivation for proposal was first
introduced to avoid people
going and starting changes without having the resourcing to actually
finish the work.
The people making the proposals are the same that need to fund it (with
their own time,
typically, but nothing prevents others from chiming in and helping of
course).
This is something obvious for those that have contributed to the project
for a long time,
but maybe not so for others. So... this activity is funded/resourced
already right?
On Fri, Mar 23, 2018 at 11:40 AM, Jody Garnett <jody.garnett@anonymised.com
<mailto:jody.garnett@anonymised.com>> wrote:
We had a chance to write up a proposal for GeoTools - to introduce
ResourceInfo2.getStyles():
- https://github.com/geotools/geotools/wiki/ResourceInfo2-with-Style
<https://github.com/geotools/geotools/wiki/ResourceInfo2-with-Style>
I think allowing DataStore developers to control the presentation of
their "native" styles is worth while.
On Thu, Mar 22, 2018 at 9:44 AM Richard Duivenvoorde
<rdmailings@anonymised.com <mailto:rdmailings@anonymised.com>> wrote:
On 22-03-18 02:59, Jody Garnett wrote:
> We have a similar need with shape files, the presence of a sidecar SLD
> file is great way to pass styling around.
> At a GeoTools level I would love a way to "discover" a built-in style
> for a layer so we could make it available for either a) GeoServer Data
> Import (sadly that would just be a one time solution), or see we could
> make a placeholder in the LayerInfo (maybe with a special default style
> placeholder.
> GeoTools does have a per layer "info" data structure used to pass meta
> information on to the application, we could see about making the style
> available in this manner.
Hi Jody,
about sidecar SLD: if I'm correct esri products used a lyr file
next to
a shapefile automatically if it had the exact same name.
QGIS is doing the same when you have a .qml (QGIS stylefile)
with the
same name.
Unfortunatly that does not work (yet) with sld files (in QGIS),
but it
could be a usable model... if you want to keep working with
shapefiles
In case of Geopackage/Spatialite I would think a 'packaged'
style could
be favoured over sld styles in Geoserver? Indeed it would be best if
GeoTools could serve this information.
Check out the vibrant tech community on one of the world's most
Geoserver-devel mailing list
<mailto:Geoserver-devel@lists.sourceforge.net>
<https://lists.sourceforge.net/lists/listinfo/geoserver-devel>
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio
stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti,
copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento
contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
Protection Code).Any use not in accord with its purpose, any disclosure,
reproduction, copying, distribution, or either dissemination, either
whole or partial, is strictly forbidden except previous formal approval
of the named addressee(s). If you are not the intended recipient, please
contact immediately the sender by telephone, fax or e-mail and delete
the information in this message that has been received in error. The
sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility
for changes made after they were sent or for other risks which arise as
a result of e-mail transmission, viruses, etc.
Geomaster, Lda
Avenida Barros e Soares, 423
Nogueira
4715-214 Braga
NIF 510906109
Tm +351 910333888
Email jgr@anonymised.com
Site geomaster.pt
GPS 41.53322,-8.41929
