[Geoserver-devel] SLD from Postgis or from GeoPackage
The GeoPackage standard lacks definitions about how to deliver styles with data but I know that it has been discussed in the OGC working group. It would be right time now to think about how it could be done well and make a suggestion. I believe that suggestions can leak to gpkg working group even from geoserver-devel list, but perhaps a reasoned mail to contacts listed in http://www.opengeospatial.org/projects/groups/geopackageswg could be more effective. Perhaps saving SLD into some specific gpkg_style_table is not the best option for the future.
-Jukka Rahkonen-
Lähettäjä: Andrea Aime [mailto:andrea.aime@…1268…]
Lähetetty: 22. maaliskuuta 2018 10:59
Vastaanottaja: Jorge Gustavo Rocha <jgr@…4991…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] SLD from Postgis or from GeoPackage
Hi Jorge,
summarizing what others said and adding a few bits of my own. You’d need (top to bottom):
  • A notion of “layer local style” in the configuration, right now styles are global and are just linked to the layer. Basically, what Nuno said. And add UI for it, what you said, but without “postgis” in the title, it should be generic (native styles or something like that)
  • Change all style using bits (GetCapabilties, GetMap, GetFeatureInfo, GetLegendGraphic, GetStyles) to recognize this new type of style (GetCapabilities) and make a call to the ResourcePool that would look something like getStyle(LayerInfo, styleName)
  • Have a generic way for datastores to publish a local style, basically what Jody said, using the Info data structure, that would have to be extended
  • Implementation wise, GeoPackage and Postgis are actually two dialects of JDBCDataStore (one class for all JDBC based stores), the SQLDialect woudl have to be extended to locate native styles if present
  • There is the issue of name conflicts, a native style name could overlap a configured one… in this case, if the native one is configured to be published, I guess it would have to take precedence on the other
GeoServer wise there is a core API change, so a improvement proposal + vote is needed, GeoTools wise, meh… it’s more or less the same (ResourceInfo interface is public API that would need to be extended). Personally the GeoTools change looks smaller to me and I’d be content with just a mail discussion on geotools-devel, but it’s just my feeling about it, writing a proposal is indeed just a little effort more.
Hope this helps!
On Wed, Mar 21, 2018 at 3:31 PM, Jorge Gustavo Rocha <jgr@…4991…> wrote:
Hi devs,
QGIS can save the style back to the provider (to Postgis and to
GeoPackage). The style is stored on a table called layers_style. On
Postgis, the table is stored in the public schema.
The table has a column to store the native QGIS style format and another
column to store the SLD style (stylesld).
I would like to use the SLD style stored on layers_style table on
Geoserver. It would improve the interoperability between QGIS and Geoserver.
It can be done both for Postgis and for GeoPackage stores. For example,
when publishing a GeoPackahe layer, it would be nice to use the SLD
already stored in the GeoPackage. The same for Postgis.
The layers_table [1] also has a useasdefault column. It would be super
cool to immediately render the layer using that default style for the layer.
I would appreciate your feedback regarding this use case.
I’ve done a simple mockup [2] to improve the Publishing tab for the
layer. It adds one more list of styles. The user can choose from the
‘Available styles’ list and also from the ‘Available style in Postgis’
(or ‘Available style in GeoPackage’) list.
The store (when connecting to Postgis) is always related with a schema
that might be not the public. To support this use case, we need to add
an additional connection to the database to the public schema using the
same credentials.
Regards from Bonn Code Sprint,
Jorge Gustavo
[1] CREATE TABLE public.layer_styles (
id integer NOT NULL DEFAULT nextval(‘layer_styles_id_seq’::regclass),
f_table_catalog character varying COLLATE pg_catalog.“default”,
f_table_schema character varying COLLATE pg_catalog.“default”,
f_table_name character varying COLLATE pg_catalog.“default”,
f_geometry_column character varying COLLATE pg_catalog.“default”,
stylename text COLLATE pg_catalog.“default”,
styleqml xml,
stylesld xml,
useasdefault boolean,
description text COLLATE pg_catalog.“default”,
owner character varying(63) COLLATE pg_catalog.“default”,
ui xml,
update_time timestamp without time zone DEFAULT now(),
CONSTRAINT layer_styles_pkey PRIMARY KEY (id)
[2]
https://www.dropbox.com/s/nh72i4tv21y1h0o/mockup%20with%20styles%20from%20postgis.png?dl=0
Geomaster, Lda
Avenida Barros e Soares, 423
Nogueira
4715-214 Braga
NIF 510906109
Tm +351 910333888
Email jgr@…4991…
Site geomaster.pt
GPS 41.53322,-8.41929
Geoserver-devel mailing list
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
