[Geoserver-devel] sld functionality
I get an error that I believe is from a CSSParameter
151306281 [INFO] org.geotools.renderer.style.SLDStyleFactory - Bad file name in
SLDStyleFactoryserif
java.io.FileNotFoundException: serif (The system cannot find the file specified)
alos is there a way to use a route sign for marking roads via sdl ( like google maps does)
I can show the icon, but I want to put the route number on top of it.
Jason J. Kahler
Software Engineer
BAE Systems
428 Phoenix Drive
Griffiss Business and Technology Park
Rome, NY 13441
Phone: (315) 339 3393 X177
name in
specified)
I believe that the SLD code should move on to the next font available
and then choose a default if it can't find any of the ones you
specified. This is why its reported as INFO and not an error.
google maps does)
You need another rule using a textsymboliser with a point placement
that draws the label over the symbol.
Ian
Ian Turton
http://www.geotools.org
http://www.ccg.leeds.ac.uk
