+1
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente email
(il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential
or otherwise protected from disclosure. We remind that - as provided
by European Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other than the
intended recipient is prohibited. If you have received this email by
mistake, please notify us immediately by telephone or e-mail.
On Fri, Jun 29, 2018 at 5:28 PM Mauro Bartolomeoli
<mauro.bartolomeoli@anonymised.com> wrote:
Hi, an update on my work on SLDService, so that anyone interested can chime in with ideas:
- adding a fullSLD (true/false) parameter to the actual classify REST controller; when true I would always return the full SLD ignoring the requested format (or eventually returning an exception if it's not XML)
First of all, I would go with adding the fullSLD parameter.
In addition, to allow a more flexible usage of the service I would like to introduce a bunch of new paramters:
- colors: list of comma delimited colors to generalize the current start, end and mid colors (to allow more precise palette specification from the client)
- customClasses: list of comma delimited classes (each class is a semicolon delimited min, max and color list) to allow a completely client driven SLD generation (this is useful if the client allows the user to build a custom list of classes); the service would still be useful to translate the list to a real SLD (any preference for a distinct REST API entrypoint for this purpose?); obviously this makes sense if the # of classes is not that big
- strokeWeight, strokeColor: a way to customize polygons stroke style instead of using the default one
More important I will add support for viewparams, so that SQLViews can be used with the service too.
Mauro Bartolomeoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-devel mailing list
