Quoting dblasby@anonymised.com:
Here's what I'm planning on doing over the next little while:
1. Adding Spatial DB in a Box functions to Filter ("<Function
name=...>"). James and his crew have done a bunch of infrastructure
on
this, so I dont expect this too be too difficult.
Cool.
2. Add in Geoserver support for <NamedStyle>. Basically, this lets
you
"include" another SLD in your SLD.
<NamedStyle>
<Name>CenterLine</Name> <!-- this refers to another
SLD-->
</NamedStyle>
There's a bit of Geotools support for this, but its needs quite a bit
of
work:
a) it needs a repository of named styles (already existing in
Geoserver)
b) it needs support to do the actual include/render properly.
c) it needs geoserver support for when the user updates one of
the
styles (depending on how B is implemented)
Anyone have any ideas on how to do this?
Well, if we do the repository of named styles in GeoTools (and I don't
really see another way to do it), then I would think that GeoServer
should just use that data structure directly, so that when a style is
updated it updates the geotools repository. And thus when the style is
parsed it will pick up the updated one from the gt2 repository. As for
b) I think the replacement would take place at the Style parsing level,
no? That it would affect the fields in the Style object we make?
Though GeoTools has this difference between SLD and Style which I never
quite understood, and I feel like named styles might be at the SLD
level? And god the error checking for it is so bad.
3. SLD post
Anyone have any ideas on how to do this one?
Er. Your options are figure out XDO and use it. Or else you could use
pure DOM, as that's what the SLD reader is written in. This breaks
habit in GeoServer, as we're all about SAX, but I imagine it'd end up
even nastier if you were to try to do a mixed SAX/DOM parser. And the
fields you need to figure out are pretty trivial anyways. So all you'd
need to do is extend geoserver.util.requests.readers.XmlRequestReader
and implement the read method in a GetMapXmlReader. Get your dom tree,
extract out the GetMap params that you need, put them in the GetMap
request, and then read the SLD with the SLD reader. This should
actually end up working just as well as the Get reader, and thinking on
it shouldn't be too hard to implement. I can't find a schema for the
POST GetMap request, but the sld spec has a sample. Though actually
with DOM the order doesn't even matter so much, you just have to find
them.
Chris
dave
This mail sent through IMP: https://webmail.limegroup.com/
This SF.Net email is sponsored by Oracle Space Sweepstakes
Want to be the first software developer in space?
Enter now for the Oracle Space Sweepstakes!
http://ads.osdn.com/?ad_id=7393&alloc_id=16281&op=click
Geoserver-devel mailing list
