org.xml.sax.SAXParseException: cvc-complex-type.2.4.a: Invalid content was found starting with element ‘ogc:Function’. One of '{"http://www.opengis.net/ogc":PropertyName}’ is expected.
found starting with element 'ogc:Function'. One of
'{"http://www.opengis.net/ogc":PropertyName\}' is expected.
How to modify the SLD file?
Don't modify the file, you just need to ignore the error message, what
you are using is an extension to the standard SLD,
that's why it does not validate against the schemas.
Btw, you're asking questions on the wrong mailing list, this one is to
discuss the GeoServer own code and manage the
project, people using GeoServer should ask questions on the users
mailng list instead
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
