[Geoserver-devel] SLDService community module
recently we did some work on the sldService community module (an ad hoc rest service to create SLD for a layer using classification functions on one of its attributes).
We would like to contribute back the work (mainly bug fixes, small feature improvements and documentation) and readd the module to the modules list in the community pom.xml (and possibly enable nightly build).
Any objections to adding the module to the built modules list and nightly builds?
Thanks
Mauro
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
No real objection, I trust the tests do not take much time. Is there any plans to make this one an extension?
Right now we reserve being included in the nightly build for extensions and a few community modules depended on downstream. Importer was a good example as it was used in OpenGeo Suite.
I always felt okay about that as the modules had a maintainer, even if they did not have docs and QA up to project standards.
On Tue, Dec 9, 2014 at 5:45 AM Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Thanks
Mauro
@mauro_bart
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk_______________________________________________
Geoserver-devel mailing list
Geoserver-devel@anonymised.comsourceforge.net
2014-12-09 18:12 GMT+01:00 Jody Garnett <jody.garnett@anonymised.com>:
Not immediately, I think more work is needed for that.
Ok, reasonable.
Thanks
Mauro
@mauro_bart
On Tue, Dec 9, 2014 at 6:12 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
One observation, tests for community modules take exactly zero time,
because we do not run them.
A module needs to be elevated to extension status to have its tests run, as
long as it stays in
community it's free to bit rot as it pleases (well, we notice compile
failures for those that are
included in the nightly, but that's all, and even in that case if there is
no time/interest in
keeping them around, we just kick them out of the nightly).
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Ciao,
I would say that the interest here in the long run is to push this
kind of functionalities into at least an extension.
We do have a couple of users/clients asking for something like this to
be core in GS.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Wed, Dec 10, 2014 at 9:25 AM, Andrea Aime
One observation, tests for community modules take exactly zero time, because
we do not run them.
long as it stays in
no time/interest in
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
Good clarification Andrea, and to repeat no problem adding this one into the nightly build.
On 10 December 2014 at 00:25, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
One observation, tests for community modules take exactly zero time, because we do not run them.
A module needs to be elevated to extension status to have its tests run, as long as it stays in
community it’s free to bit rot as it pleases (well, we notice compile failures for those that are
included in the nightly, but that’s all, and even in that case if there is no time/interest in
Ing. Andrea Aime
@geowolf
Technical Lead
