I’ve been spending some time looking as to why our tests are so slow, so I’ve profiled
a WFS surefire process while it was running our tests.
Here is a breakdown from the main method:
root) org.apache.maven.surefire.booter.ForkedBooter.main(String) 94094 0
setup) org.geoserver.test.GeoServerBaseTestSupport.doSetup() 49714 0
test-methods) sun.reflect.NativeMethodAccessorImpl.invoke0(Method, Object, Object) 35130 0
The test-methods root contains all the single test methods runs, e.g.:
org.geoserver.wfs.ExternalEntitiesTest.testWfs1_1() 932 0
org.geoserver.wfs.AliasTest.testAliasFifteen() 856 0
org.geoserver.wfs.GetFeaturePagingTest.testStartIndexMultipleTypesPOST() 755 0
org.geoserver.wfs.GetFeaturePagingTest.testStartIndexMultipleTypes() 584 0
and so on
So… we are spending 53% of our build time running the various setups… not nice.
And here is how the doSetup breaks down:
So, we are spending 32% of our overall build time running security subsystem data directory migrations…
that really needs to be fixed, I believe, it’s pretty much the same time we spend actually running
test methods…
I guess the best approach would be to make sure that we generate the security subsystem config
already at the latest version required.
But, there is something else going on here, those migration result in a insane amount of calls to
the GeoServerSecuritManager.persister(), which in turns creates a XStream persister from
scratch. Have a look, we call that method 300.000 times during the WFS test build alone:
I believe there is something fishy going on there, like, I see the HelperBase.loadConfig class
called over and over loading the same files, I’m afraid there might be some sort of event escalation
(like, changing one of the security config files, which results in the whole security being reloaded,
then change another, and so on).
The code seems in need of a refactor, where a single persister is reused for all the migration operations.
Christian, do you have some time to look into this issue? By comparisong, loading the catalog
from the many little config files takes only 3 seconds overall, that is, 1/10th of the time we spend
doing these migrations.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
