[Geoserver-devel] Small new feature for GetFeatureInfo: rule match count
I’m writing this mail to propose (on behalf of a sponsor) a small new feature for GetFeatureInfo,
that is, the ability to report the number of matched features in the requested area as part
of the legend.
It is not the more commonly requested “show only the entries with at least one item in the map”,
but it lowers its implementation bar significantly, making it more likely to get sponsored in the future.
The request would look like:
http://host/geoserver/wms?REQUEST=GetLegendGraphic&VERSION=1.0.0&FORMAT=image/png&WIDTH=20&HEIGHT=20&LAYER=topp:states // std legend graphics so far
&SRS=EPSG%3A4326&SRCWIDTH=768&SRCHEIGHT=330&BBOX=-97.7783203125%2C37.078857421875%2C-89.3408203125%2C40.704345703125 // identify area of interest
&LEGEND_OPTIONS=countMatched:true // activate the counting mode
In order:
  • A standard GetLegendGraphics request, but with a layer parameter (normally optional, but mandatory in this case)
  • The part of a GetMap that identifies the current area, using the same syntax as GetMap, minus the “src” prefix for width and height, as they would otherwise conflict with the legend icon size
  • A legend option to enable it (the implementation of the “return only the rules show in the map” would differ only in this bit)
    The output would be something like this, with the count within parenthesis: (graphics as text for the sake of expediency):
[greenSquare] Parks and green spaces (10)
[blueSquare] Water (3)
[graySquare] Urban (150)
Implementation wise, I’m still a bit torn between a CountVisitor call and a StreamingRenderer pass, but I believe
I’ll do the second. Rationale: the logic of a count would need to consider symbols sizes and whether the output
actually contributes to the visible map, and with a thematic map would end up having to issue multiple queries,
and would end up returning a count that does not always exactly match the map on screen.
A StreamingRenderer call against a fake Graphics2D would do a single pass instead (faster than the equivalent
GetMap for sure) and would end up counting what the user actually sees instead (it would be in line with
the current GetFeatureInfo implementation, doing the same).
Feedback welcomed. If you think something needs to be changed I would appreciate if you could mark
such comments clearly (I often get confused by comments that is not meant to ask for a change, but could be
interpreted as such).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Looks like nobody is particularly concerned, so moving on with current plan
On Mon, Apr 24, 2017 at 2:59 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
of the legend.
In order:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Sorry, forgot to hit send on my draft.
I like this idea and I think the streaming renderer pass is the better route as it should give the answer the user is expecting (at least for small numbers where they might count by hand :-))
Ian
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
of the legend.
In order:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
+1 for the plan, option name of countMatched, and StreamingRenderer for consistency with what the user sees.
Kind regards,
Ben.
wrote:
I'm writing this mail to propose (on behalf of a sponsor) a small new
of the legend.
It is not the more commonly requested "show only the entries with at least
one item in the map",
VERSION=1.0.0&FORMAT=image/png&WIDTH=20&HEIGHT=20*&LAYER=topp:states* //
*&SRS=EPSG%3A4326&SRCWIDTH=768&SRCHEIGHT=330&BBOX=-97.7783203125%2C37.078857421875%2C-89.3408203125%2C40.704345703125
// *identify area of interest
*&LEGEND_OPTIONS=countMatched:true // activate the counting mode*
In order:
   - A standard GetLegendGraphics request, but with a layer parameter
   - The part of a GetMap that identifies the current area, using the
   same syntax as GetMap, minus the "src" prefix for width and height, as they
   - A legend option to enable it (the implementation of the "return only
   the rules show in the map" would differ only in this bit)
Implementation wise, I'm still a bit torn between a CountVisitor call and
I'll do the second. Rationale: the logic of a count would need to consider
map on screen.
Feedback welcomed. If you think something *needs* to be changed I would
Ing. Andrea Aime
@geowolf
Technical Lead
phone: +39 0584 962313 <+39%200584%20962313>
fax: +39 0584 1660272 <+39%200584%20166%200272>
mob: +39 339 8844549 <+39%20339%20884%204549>
Check out the vibrant tech community on one of the world's most
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
implementation here (with streaming renderer, docs, and some extras to make it work along map decorations as well… because it made for a nice example in the docs):
https://github.com/geoserver/geoserver/pull/2296
of the legend.
In order:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Andrea, reviewed/merged during this mornings meeting.
On 2 May 2017 at 05:45, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
of the legend.
In order:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
