+1
-Jukka Rahkonen-
Ben Caradoc-Davies wrote:
Re: [Geoserver-devel] Small new feature for GetFeatureInfo: rule match count
+1 for the plan, option name of countMatched, and StreamingRenderer for
consistency with what the user sees.
Kind regards,
Ben.
On 26/04/17 21:50, Andrea Aime wrote:
Looks like nobody is particularly concerned, so moving on with current plan
AndreaOn Mon, Apr 24, 2017 at 2:59 PM, Andrea Aime <andrea.aime@...1268...>
wrote:Hi,
I'm writing this mail to propose (on behalf of a sponsor) a small new
feature for GetFeatureInfo,
that is, the ability to report the number of matched features in the
requested area as part
of the legend.
It is not the more commonly requested "show only the entries with at least
one item in the map",
but it lowers its implementation bar significantly, making it more likely
to get sponsored in the future.The request would look like:
http://host/geoserver/wms?REQUEST=GetLegendGraphic&
VERSION=1.0.0&FORMAT=image/png&WIDTH=20&HEIGHT=20*&LAYER=topp:states* //
std legend graphics so far
*&SRS=EPSG%3A4326&SRCWIDTH=768&SRCHEIGHT=330&BBOX=-97.7783203125%2C37.078857421875%2C-89.3408203125%2C40.704345703125
// *identify area of interest
*&LEGEND_OPTIONS=countMatched:true // activate the counting mode*In order:
- A standard GetLegendGraphics request, but with a layer parameter
(normally optional, but mandatory in this case)
- The part of a GetMap that identifies the current area, using the
same syntax as GetMap, minus the "src" prefix for width and height, as they
would otherwise conflict with the legend icon size
- A legend option to enable it (the implementation of the "return only
the rules show in the map" would differ only in this bit)The output would be something like this, with the count within
parenthesis: (graphics as text for the sake of expediency):[greenSquare] Parks and green spaces (10)
[blueSquare] Water (3)
[graySquare] Urban (150)Implementation wise, I'm still a bit torn between a CountVisitor call and
a StreamingRenderer pass, but I believe
I'll do the second. Rationale: the logic of a count would need to consider
symbols sizes and whether the output
actually contributes to the visible map, and with a thematic map would end
up having to issue multiple queries,
and would end up returning a count that does not always exactly match the
map on screen.
A StreamingRenderer call against a fake Graphics2D would do a single pass
instead (faster than the equivalent
GetMap for sure) and would end up counting what the user actually sees
instead (it would be in line with
the current GetFeatureInfo implementation, doing the same).Feedback welcomed. If you think something *needs* to be changed I would
appreciate if you could mark
such comments clearly (I often get confused by comments that is not meant
to ask for a change, but could be
interpreted as such).Cheers
Andrea--
http://goo.gl/it488V for more information.Ing. Andrea Aime
@geowolf
Technical LeadGeoSolutions S.A.S.
Via di Montramito 3/A
phone: +39 0584 962313 <+39%200584%20962313>
fax: +39 0584 1660272 <+39%200584%20166%200272>
mob: +39 339 8844549 <+39%20339%20884%204549>http://www.geo-solutions.it
http://twitter.com/geosolutions_it*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
principi dettati dal D.Lgs. 196/2003.The information in this message and/or attachments, is intended solely for
e-mail transmission, viruses, etc.-------------------------------------------------------
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@...4191...>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
