Dear all,
I’m writing to ask permission to add new Smart Data Loader community module.
The module provides a new Data Store and a UI to generate automatically App-Schema configuration mappings as well as the complex type gml definition.
For the moment only PostGIS is supported, and tests are all meant to be run with a live connection to a PostGIS DB.
Here https://github.com/geoserver/geoserver/pull/4817 you can find the pull request to master.
Best regards,
Marco Volpini
Also known as, “Take a sane relational db, point the GUI at it, generate complex features in minutes”.
It’s basically similar to what we do with simple features, reflecting the structure of the database without the need
to write a mapping. For many, there is no need to abide by a particular schema, as long as the data is published.
Anyways, +1
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1 for me, sounds like a useful tool.
Ian
Ian Turton
