On Fri, Nov 20, 2015 at 8:35 PM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:
Thanks very much, Jukka. I am pleased by your thorough testing.
It almost seems worth automating this process to catch missing jars as
this has happened before. For each plugin, unpack the bin.zip, install the
plugin, and try to start geoserver. A Jenkins parameterised build, perhaps?
Hum... one by one is one thing, other issues can raise out of combinations
but... to go there it would mean testing
a lot of possible combinations (if we do the power set, 38! is an awfully
large number) , with a startup for each one.
But yeah, if we have someone willing to setup that build, it would help
catch some issues, like missing jars,
that tend to happen when we promote new modules to extension
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
