While testing I noticed that module directory names in geoserver-2.6.4-src.zip are wildly inaccurate and do not match the pom, causing the build to fail. But we no longer use this archive, as the release pages link to GitHub source code archives, which are automagically generated on demand for any tag.
Should we remove the generation of geoserver-*-src.zip from the geoserver-release script as the output is just broken cruft?
yes we should remove the generation of the src.zip files if you have a chance!
Sure. I checked and it is not the geoserver-release script but the top-level pom that causes assembly of geoserver-*-src.zip. Removing release/src.xml and its mention in the top level pom should prevent the creation of geoserver-*-src.zip files during the assembly phase. I will test that my understanding is correct and submit some pull requests.
Kind regards,
Ben.
chance!
Director
Transient Software Limited <http://transient.nz/>
New Zealand
chance!
Director
New Zealand
