The internationalization UI is … ugly? Digging into it there is a <br/> tag producing a lot of wasted space, rather than use of css which offers some more control.
I just noticed because it looks much better in the UI screen snap that Andrea used for the State of GeoServer presentation, when I run locally there is a lot more white space so that the contact information page takes 2-3 screens (rather that one).
I had real trouble understanding what you were talking about here… the layer page looked good and the component was conforming to the proposal,
the i18n component is not a work of art but was delivered as promised:
Then I looked at the contact page and… aaah, there it is:
Way too much space between components. Ok, I agree we have a problem
