[Geoserver-devel] Some checkboxes do not work with Firefox
There is this open ticket about not responding check box
http://jira.codehaus.org/browse/GEOS-6036
I found another similar case on the Edit Raster Data Source page where the “Enabled” check box can’t be toggled with Firefox 35.0.1 on Windows. The Editable box on the vector store page works. I wonder if it could it be possible to do some Find-Replace operation in the UI code and try to change all boxes which do not work into same kind of boxes which work on the vector store page.
-Jukka Rahkonen-
On Mon, Feb 9, 2015 at 1:50 PM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
vector store page.
I wish it was that easy. The issue is CSS related, does not have anything
to do with the UI control chosen. Someone with good understanding of how
Firefox interprets the CSS is needed to solve the issue.
If memory serves me right, It's the hit area of other nearby HTML elements
that is covering the checkbox making it impossible to click.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
