[Geoserver-devel] Some experiments/thoughs on mass reformat
I’ve been experimenting a bit with mass code base reformats approaches on GeoTools (used as a guinea
pig and hoping to transfer the same approach on GeoWebCache and Geoserver too, hence the
cross post).
I wrote a document to share my findings here (read only, but can be commented on), along with links
to branches where the reformatting happened:
https://docs.google.com/document/d/1_ub38YX2juf7uM8S8fywUTNzF5j9Zho-Jo5O_dXvI-Y/edit#
Originally I was thinking of approaching mass reformat in a code sprint, but since we have none planned,
a “lightweight” approach doing the smallest amount of work for the greatest benefit seems also
feasible.
Of the reformat approaches above, I cannot argue with the tooling and effectiveness of the Google style one,
but indenting only 2 spaces leaves me a bit “cold”, the code is flatter and structures seem harder to
locate… it may well be just a matter of habit.
The intellij command line one + checkstyle changes our approach to formatting less, but will
require more manual work on setting up checkstyle the way we want it, and seems to have more
overhead
So… would you like to see one of these actually committed and enforced?
Expressions of interest to help in this endeavor?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Andrea,
the Google formatter looks like the strongest candidate, despite my sharing your lack of fondness for two-space indentation.
(1) Is it idempotent? That is, if you run the formatter a second time, does it change anything? There are some outstanding issues:
https://github.com/google/google-java-format/issues/254
https://github.com/google/google-java-format/issues/211
(2) Do we have a plan for Eclipse formatter:off and formatter:on tags? This is also discussed:
https://github.com/google/google-java-format/issues/137
Thanks for the interesting review of these tools. You had a fun weekend!
Kind regards,
Ben.
On 11/03/18 22:54, Andrea Aime wrote:
I've been experimenting a bit with mass code base reformats approaches on
too, hence the
cross post).
a "lightweight" approach doing the smallest amount of work for the greatest
benefit seems also
feasible.
but indenting only 2 spaces leaves me a bit "cold", the code is flatter and
locate... it may well be just a matter of habit.
seems to have more
overhead
So... would you like to see one of these actually committed and enforced?
Ing. Andrea Aime
@geowolf
Technical Lead
Check out the vibrant tech community on one of the world's most
GeoTools-Devel mailing list
GeoTools-Devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/&gt;
New Zealand
The lack of customizability for the google formatter concerns me, especially once we start thinking about GeoServer (and I am also not a fan of enforced two-space indentation). I’ll also echo Ben’s comment about idempotency, that is a significant concern.
In particular, the Spring MVC Controllers in GeoServer have some nonstandard indentation that is included primarily for the sake of code clarity, e.g: https://github.com/geoserver/geoserver/blob/master/src/restconfig/src/main/java/org/geoserver/rest/catalog/LayerController.java#L136-L138
I believe there are other similar structures elsewhere that skirt the boundaries of our current rules for sake of readability (such as large boolean logic expressions, inline comments indented to be in line with applicable code, large concatenated string blocks indented to be more readable, and others), although I don’t have any specific examples at the moment.
A formatter which allows for customizability should be able to preserve this sort of stuff, but one that isn’t
I tried out the Intellij formatter on GeoServer on OS X, and a couple notes (branch):
  • It took 4 minutes to format all of GeoServer
  • Running the formatter a second time took 2.5 minutes, and altered 5 files, so not quite idempotent. A third time showed no changes, so it is likely that the initial formatting changes caused changes that required further formatting. Overall, not likely to be a serious issue.
  • I had to use slightly different command syntax - notably I needed the full path to the source directory, at the end of the command:
/bin/format.sh -r -m “*.java,pom.xml” -s <gs_source>/workspace/formatter.xml <gs_source>/geoserver/src
  • The Intellij formatter preserved the argline example in LayerController linked above as-is.
I also tried the fmt-maven-plugin on GeoServer (branch):
  • Since its part of the build, not quite sure how fast it was, but seemed pretty fast; full GeoServer build with reformatting (skipping tests) took 3 minutes (And I think maven downloaded a few jars .
  • Second pass of formatting changed 6 files. Third pass changed none, so the current version seems to be adequate with respect to idempotency.
  • Looking at some of the changes made, we get stuff like this:
String groupSearchFilter; //more appropriate name would be groupMembershipFilter - XStream backwards compatibility
becoming:
String
groupSearchFilter; // more appropriate name would be groupMembershipFilter - XStream backwards
// compatibility
Which seems to be pretty bad formatting. So that is a mark against the google formatter.
  • Formatting retained adequate legibility with respect to the argline example, by automatically moving the first argument to a newline, so that is promising:
@PutMapping(value = "/{layerName}")
public void layerPut(
    @RequestBody LayerInfo layer,
    @PathVariable String layerName,
    @PathVariable(required = false) String workspaceName) {
Overall, I think I prefer the Intellij formatter, due to customizability and four-space indentation.
Torben
On Sun, Mar 11, 2018 at 1:45 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Andrea,
Kind regards,
Ben.
too, hence the
cross post).
benefit seems also
feasible.
seems to have more
overhead
Ing. Andrea Aime
@geowolf
Technical Lead
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
GeoTools-Devel@anonymised.comge.net
Director
Transient Software Limited <https://transient.nz/>
New Zealand
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Especially XML documents included in code, such as those used in test fixtures. My workaround before I started using @formatter:off was trailing // comments to defeat the Eclipse formatter.
    - Looking at some of the changes made, we get stuff like this:
becoming:
      String
      // compatibility
    google formatter.
Yes, that is terrible.
Kind regards,
Director
New Zealand
Ok,
so far it seems that there is a preference for the intellij approach.
Mind, in that case idempotence is not as important because we’d be doing the formatting only once (it’s a manual process
not integrated in the build), and then rely on checkstyle for verifying violations.
This is also the path requiring the most work, checkstyle seems to be mostly about best practice and less about formatting,
so not sure how much we can actually automate in terms of keeping the formatting pristine, but at least some checks we
can use, like not using tabs and having proper indentation.
We’ll have to spend some time figuring out a suitable configuration and then see if we want to add extras on top of it
(e.g. constants all uppercase and the like) which likely will require manual intervention on the code to actually pass.
Is it something that we can organize and share effort on?
On Tue, Mar 13, 2018 at 2:21 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
    becoming:
    String
    // compatibility
    google formatter.
Kind regards,
Director
New Zealand
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks for moving this along Andrea, now is a good time as we reach the end of the code freeze
To that end here is a proposal page for your preferred option: https://github.com/geotools/geotools/wiki/GeoTools-Codebase-Reformat
On 14 March 2018 at 02:33, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ok,
GeoTools-Devel@anonymised.com66…sourceforge.net
Jody Garnett
    becoming:
    String
    // compatibility
    google formatter.
Kind regards,
Director
New Zealand
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Jody,
thanks for getting the proposal started.
This is something I’m doing solely in my spare time, so resourcing is a problem. I’ll see what I can do, not sure I can do it alone.
I started this thread also to gauge interest in helping getting it done.
On Thu, Mar 15, 2018 at 12:17 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Ok,
    becoming:
    String
    // compatibility
    google formatter.
Kind regards,
Director
New Zealand
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Understood, indeed why I made the page. Let’s use the tasks section to line up volunteers before voting.
If the process is solid it may be suitable for code sprint. Assume reformatting won’t violate our code freeze.
On Thu, Mar 15, 2018 at 12:17 AM, Jody Garnett <jody.garnett@anonymised.com…> wrote:
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ok,
On Tue, Mar 13, 2018 at 2:21 AM, Ben Caradoc-Davies <ben@anonymised.com1…> wrote:
    becoming:
    String
    // compatibility
    google formatter.
Kind regards,
Director
New Zealand
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Hi Andrea,
I’ll be able to provide some assistance.
One comment on the proposal - checkstyle should be in place when we merge the formatting changes to master; would be an good first test.
Torben
On Thu, Mar 15, 2018 at 9:19 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
On Thu, Mar 15, 2018 at 2:43 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
Jody Garnett
Geoserver-devel@anonymised.com.366…sourceforge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ok,
GeoTools-Devel@anonymised.comsourceforge.net
    becoming:
    String
    // compatibility
    google formatter.
Kind regards,
Director
New Zealand
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Mar 15, 2018 at 6:10 PM, Torben Barsballe <
tbarsballe@anonymised.com> wrote:
Hi Andrea,
I'll be able to provide some assistance.
Yep. Indeed the manual work needed for this approach is (I believe).
   - Close as many pull requests as possible (big conflict wave
   approaching!)
   - Figure a suitable checkstyle setup, the out of the box ones do much
   more than we want (we can add extras later)
   - Quickly do pull requests for all branches, one project at a time
And of course, I'd like to hear from the other community members about this
too, since everybody is going to be affected :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
