after GSIP-155 landed I’ve also merged https://osgeo-org.atlassian.net/browse/GEOS-7954
which saves the datastore connection checks if the capabilities generation is setup to
skip misconfigured layers.
Then, worked on some little tweaks here and there, and updated the catalog bulk load
tool to optionally perform deep copies of workspaces and created a new configuration
that has a lot of stores and layers of most kinds.
In particular, took the release data dir, merged everything in it into a single workspace,
and then cloned said workspace 1000 times.
This resulted in a data directory with:
1001 workspaces
11000 stores, a mix of shapefiles, postgis, directory of shapefile, single tiff, arcgrid, mosaics
42000 layers and 42000 associated tile layers
A few numbers on this beast with the default catalog facade: -
Cold startup time: I’ve seen values between 230 seconds and 290 seconds (not sure why such a high variability)
Hot startup time: 59 seconds
Load testing a states layer stored in postgis (same as GSIP-155 benchmar), 35ms, that is, 1ms more than the GSIP-155 test with 10k layers
I’ve also loaded it in the jdbconfig (conversion took 37 mins), here are the numbers for it:
Cold startup time: 290 seconds
Hot startup time: 120 seconds
Load testing a states layer stored in postgis (same as GSIP-155 benchmark), 117ms (same as the timings in GSIP-155)
The JDBCConfig startup time is almost fully spent querying postgresql like crazy for the internal layers associated to gwc tile layers, and finding
which layers should not be cached in the in-memory GWC cache (this last one makes it do a full scan of all layers).
This marks the end of these investigations/optimizations for the time being: I see no more obvious ways to make default catalog facade faster, besides
trying to parallellize loading the catalog itself (which is hard enough, won’t try to do it in the short term).
PS: someone off line told me this work is killing jdbcconfig… I don’t quite agree.
It’s just showing that JDBCConfig is doing too much work to translate layer names into internal ids, and that some caches from name to id are needed to
make it competitive when serving OGC requests (along with some clustering support to drop the name → id cache
when names change).
JDBCConfig likely remains quite a bit faster in terms of startup time for configurations that have few cached layers,
but if the GWC configuration could also be moved inside the database then it would likely start-up in 20-30 seconds
no matter how many layers are in the catalog, while the startup time of default catalog facade depends linearly to the amount of
layers in the catalog.
All it needs is extra effort to improve it.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
