Just a heads up that some of the “gt” processes are being removed. This mostly consists of the “toy” functions that added a number; or did a simple buffer.
If you previously used “gt:buffer” you can now use “JTS:buffer”
This is being a little difficult to remove as (since these were available) many of the test cases were written with them in mind.
Jody Garnett
