[Geoserver-devel] Some headache with a old (14+ years) decision in rendering subsystem
I was looking into this geoserver ticket:
https://osgeo-org.atlassian.net/browse/GEOS-4923
The reported correctly traces it to the logic used to decide is a rule is in scale range, and indeed the
specification says:
“The MinScaleDenominator and MaxScaleDenominator elements, as their names
suggest, are simply the minimum and maximum ranges of scale (denominators) of maps
for which a rule should apply. The minimum scale is inclusive and the maximum scale is
exclusive”
I checked if StreamingRenderer does the same, and indeed, it does. Went back with svn to
the initial commit of “LiteRenderer” by yours truly in 2003 (I cannot find an older renderer package
in there, we are talking about the original 2.0.x branch!) and the logic with tolerance was already there.
Now… I can understand the tolerance, clients and servers are almost never computing
the value with the exact same precision (think float vs double, or just slight variations in the expression
setup), but indeed hitting a threshold scale exactly makes both rules to trigger…
Soo… possible approaches:
  • Just remove the tolerances altoghether. Simple,clean, we’ll get some users complaining that their client is stating a scale at which rules should trigger, and they don’t
  • Remove it only from max scale denominator check? It’s still possible to make the two rules trigger but getting at a value between target and “scale - tolerance”
  • Add some sophisticated logic that favours the min rules in case we have both? (but not fully sure how to write it)
    More ideas? Suggestions? Any takers?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
I have a spend a couple of minutes looking at this expression:
(((r.getMinScaleDenominator() - BufferedImageLegendGraphicBuilder.TOLERANCE) <= scaleDenominator)
&& ((r.getMaxScaleDenominator() + BufferedImageLegendGraphicBuilder.TOLERANCE) > scaleDenominator));
In my point of view it only makes sense to use a tolerance value when checking for equality, does it make sense to use it
for > and < operators ? I don’t think so …
I always used tolerance for this kind of comparisons:
boolean equal = Math.abs(r.getMinScaleDenominator() - scaleDenominator) < BufferedImageLegendGraphicBuilder.TOLERANCE;
So as far I’m concerned the current usage of BufferedImageLegendGraphicBuilder.TOLERANCE is a bug and should be removed.
Nuno Oliveira
On 10/01/2017 09:39 AM, Andrea Aime wrote:
specification says:
exclusive”
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Hi Nuno,
say it was recoded the way you suggest, what would heppen if the are two rules using a max scale and min scale of 1000,
and someone asked exactly for a map at scale 1000?
It seems to me both rules would trigger anyways, which is not what we want… or do I need a coffee? :slight_smile:
On Mon, Oct 2, 2017 at 2:53 PM, Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
Hi Andrea,
Nuno Oliveira
specification says:
exclusive”
[Geoserver-devel@anonymised.com366...sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Nuno Oliveira
@nmcoliveira
Software Engineer
Geoserver-devel@anonymised.com.366…sourceforge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
I guess we could recode it this way:
public static boolean isWithInScale(final Rule r,final double scaleDenominator) {
return (scaleDenominator == -1)
((r.getMinScaleDenominator() < scaleDenominator)
&& Math.abs(r.getMinScaleDenominator() - scaleDenominator) < BufferedImageLegendGraphicBuilder.TOLERANCE))
&& (r.getMaxScaleDenominator() > scaleDenominator);
This should only match the rule that has the min scale set to 1000, maybe I need a coffee too :stuck_out_tongue:
If we want to be very very (very) precise I guess we shoudl start using BigDecimal.
On 10/02/2017 02:02 PM, Andrea Aime wrote:
Hi Nuno,
On Mon, Oct 2, 2017 at 2:53 PM, Nuno Oliveira <nuno.oliveira@…1268…> wrote:
Hi Andrea,
Nuno Oliveira
specification says:
exclusive”
[Geoserver-devel@...366...sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Nuno Oliveira
@nmcoliveira
Software Engineer
Geoserver-devel@…366…sourceforge.net
Andrea Aime
Nuno Oliveira
@nmcoliveira
Software Engineer
