[Geoserver-devel] Some ideas for a catalog listener interface
I'm looking into making the GeoServer catalog provide
events when layers are accessed. Something useful, for example,
for any kind of request accounting.
The idea I have in mind at the moment is pluggable listeners,
registered in the Spring context at application startup,
that would be notified each time:
- a feature type is accessed, with information about the
   query/filter used
- a feature type is modified, with information about the
   area modified
- a coverage is accessed, with information about the
   bbox read
In general the listening interface could be something like:
CatalogListener {
    void resourceRead(ResourceInfo resource, Filter filter);
    void resourceModified(ResourceInfo resource, Filter filter);
where Filter is an OGC filter stating what part of the data
is being accessed/modified. For coverages I guess it would
just be a bbox filter built on the fly.
This would form the basis for an accounting that works
not matter what service is used to access the data
(WMS, WFS, WCS, WPS, custom REST extensions of the day).
Feature type wise I think that would require adding
some event firing code inside GeoServerFeatureSource
and GeoServerFeatureStore. For read wise notifications
we just need to add event firing methods to GeoServerFeatureSource
code, for write wise stuff I guess we could rely on
the existing FeatureListener stuff (or we could use
the WFS-T transaction callbacks, but what if someone
adds a custom restlet that does change data?)
Coverage wise I think we could create a coverage reader wrapper
that does the same. Thinking about it, I believe we need a
wrapper anyways if we want to allow forcing in a SRS
into coverages like we do for vectors (something would
be very handy instead of having to fix the original
data every time by creating a .prj file).
Overhead wise we should be good considering that those
listeners are registered in the spring context, so we
could grab the list of them just once and keep it around,
and avoid firing the events at all if there is no
registered listener.
Opinions?
Andrea Aime
OpenGeo - http://opengeo.org
Very cool idea. That could lead to some very interesting extensions indeed. Since we already have a CatalogListener interface I would probably recommend a different name. Something like "ResourceAccessListener" maybe makes more sense?
Andrea Aime wrote:
   query/filter used
   area modified
   bbox read
CatalogListener {
Opinions?
Justin Deoliveira
Sure thing
Andrea Aime
