Recently I have been working on a couple of things that require the UI to be able to support paging in a more efficient way than it does now. The first is the hibernate catalog, and supporting a layer view that has to show 1000’s (or more) of layers. The second is monitoring where one can page through requests which can easily be in the millions.
I am using GeoServerTablePanel/GeoServerDataProvider as the base here, since it is very convenient to work with. Most implementations simply implement getItems() and call it a day. Which is great for working in memory but obviously does not scale up to large collections.
However, the api is nicely designed in that it allows you to override some key functions in cases such as this where you don’t want to drag all the data into memory. Those methods are:
size() : return the size of the current filtered collection
fullSize(): return the size of the unfiltered/entire collection
iterator(i,j): provide an iterator over a subset of the data
Very nice. It works great and nothing gets dragged into memory once i implement those methods properly. However, I still believe there is some room for optimization. I put in some trace logging to gather up how often each of the methods is called. And here is what I got:
size()
size()
size()
fullSize()
size()
size()
fullSize()
size()
iterator(0, 20)
As you can see size() is called often. Even implementing it with a count(*) query those calls add up, especially when the db is remote. So I tried to come up with a patch to try and reduce the calls to compute the size. The patch is attached. It is not all that pretty but a relatively simple in idea. The idea is twofold:
Try to reduce the number of calls to size by holding onto previously computed size
Take advantage of the fact that size() == fullSize() when there is no filter set
With the patch applied i am able to get the calls down to:
fullSize()
size()
size()
iterator(0, 20)
Which is a step up for sure. Further optimization could probably be done since there are still multiple calls to size… but the only way i could see to do so was by using some sort of thread local to store previously computed size but it seemed a bit much. And this optimization seems to perform well enough.
So… thoughts? I tried all the various lists that we have in the ui with the patch attached and they all work as they did before, so nothing appears to break. I did try to write some test cases but it proved difficult in this case.
-justin
Justin Deoliveira
OpenGeo - http://opengeo.org
(attachments)
GeoServerTablePanel.java.patch (5.38 KB)
