Dear all,
today I found out the latest master war contains some libraries that are not “SNAPSHOT”.
They are:
- gt-process-feature-20-20180403.122022-29.jar
- gwc-gmaps-1.14-20180403.130115-41.jar
Can I safely ignore them?
Or is there the risk of getting outdated dependencies?
Thank you
Lorenzo Pini
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Lorenzo Pini
Software Engineer
Via di Montramito 3/A
Lorenzo,
these are timestamped snapshots that were uploaded to the Boundless snapshot repo. Maven will use the most recent one. For example: Jenkins geotools-master last ran three days ago, and the gt-process-feature you found is the most recent one:
https://repo.boundlessgeo.com/snapshot/org/geotools/gt-process-feature/20-SNAPSHOT/
I have no idea why the Jenkins build did not use gt-process-feature-20-SNAPSHOT.jar from its local repo. Perhaps the GeoServer build ran on a different node? But why should only this jar be affected?
Kind regards,
Ben.
On 06/04/18 19:46, Lorenzo Pini wrote:
Dear all,
not "SNAPSHOT".
They are:
Thank you
Lorenzo Pini
Lorenzo Pini
Software Engineer
Check out the vibrant tech community on one of the world's most
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/>
New Zealand
