[Geoserver-devel] Some problems for 2.2.5 release
The geoserver-release-publish is currently giving this error:
Started by user hudson
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson7528167848804124322.sh
+ set -x
+ git checkout master
warning: unable to rmdir build/geowebcache/master/83b284b341ef25fe89adf2eb7858991defa64e57: Directory not empty
warning: unable to rmdir src/community/python/geoscript: Directory not empty
Switched to branch 'master'
+ git pull origin master
>From github-geoserver:geoserver/geoserver
 * branch            master     -> FETCH_HEAD
Already up-to-date.
+ export PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/lib/jvm/java-6-sun/bin
+ cd build
+ ./publish_release.sh 2.2.5 2.2.x mbarto [maurobartolomeoli@anonymised.com](mailto:maurobartolomeoli@anonymised.com)
Switched to branch 'rel_2.2.5'
M	build/geowebcache/master/83b284b341ef25fe89adf2eb7858991defa64e57
branch rel_2.2.5 dirty, exiting
[DEBUG] Skipping watched dependency update for build: geoserver-release-publish #42 due to result: FAILURE
Finished: FAILURE
I presume a previous build not completely cleaned. Ho can I clean the build folder and go on?
Thanks.
Mauro Bartolomeoli
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
Hmmm… I thought I recently fixed this issue. Looking at the geoserver-release-publish history i am not seing that build… was it deleted? Anyways it seems to have worked itself out?
On Tue, Feb 26, 2013 at 5:15 AM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
+ set -x
Already up-to-date.
+ cd build
Finished: FAILURE
Thanks.
Mauro Bartolomeoli
@mauro_bart
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_feb
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
As a workaround I temporarily changed the job to remove the offending folder before doing the release. After the release I changed back the job to it’s original configuration.
I was simply doing a rm -rf && cd build && publish_release.sh
We’ll see at the next 2.2.x release if the issue is always there.
Mauro
2013/2/26 Justin Deoliveira <jdeolive@anonymised.com>
@mauro_bart
On Tue, Feb 26, 2013 at 5:15 AM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com…> wrote:
+ set -x
Already up-to-date.
+ cd build
Finished: FAILURE
Thanks.
Mauro Bartolomeoli
@mauro_bart
Justin Deoliveira
Hmmm… odd indeed. When i released from 2.3.x i didn’t run into the problem, i explicitly checked since it was a problem last time around.
On Tue, Feb 26, 2013 at 10:04 AM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Mauro
Justin Deoliveira
@mauro_bart
+ set -x
Already up-to-date.
+ cd build
Finished: FAILURE
Thanks.
Mauro Bartolomeoli
@mauro_bart
Justin Deoliveira
