[Geoserver-devel] Some research on layer nesting in WMS and some final ideas pre-proposal
so far GeoServer did not support well the concept of layer nesting (there was wms_path but
it was never working ok, we should remove it).
Most likely too accustomed to layer groups behavior I’ve made some assumptions that
on a deeper read do not seem to be warranted.
Here is an excerpt of the WMS 1.3 specification on layer nesting:
Each available map is advertised by a element in the service metadata. Conceptually, each Layer is a
distinct entity. However, as a means of classifying and organizing layers, and as a means of reducing the size of
the service metadata, a single parent Layer may enclose any number of additional layers, which may be
hierarchically nested as desired. Some properties defined in a parent layer are inherited by the children it
encloses. These inherited properties may be either redefined or added to by the child. Subclause 7.2.4.8
summarizes whether or how each property is inherited.
A server shall include at least one element for each map layer offered. If desired, layers may be repeated
in different categories (i.e. enclosed in more than one parent ) when relevant.
If, and only if, a layer has a , then it is a map layer that can be requested by using that Name in the
LAYERS parameter of a GetMap request. A Layer that contains a element is referred to as a “named
layer” in this International Standard. If the layer has a Title but no Name, then that layer is only a category title for
all the layers nested within. A server that advertises a Layer containing a Name element shall be able to accept
that Name as the value of LAYERS argument in a GetMap request and return the corresponding map. A client
shall not attempt to request a layer that has a Title but no Name.
A containing category itself may include a Name by which a map portraying all of the nested layers can be
requested at once. For example, a parent layer “Roads” may have children “Interstates” and “State Highways” and allow the user to request either child individually or both together.
First thing, a named layer can appear multiple times in the capabilities document.
This is a bit weird, in that the same layer could be nested under different parents and inherit
different base settings (say for example one parent declares a time dimension, and another does not,
this would be inconsistent…).
Then, there is a thing we do not support called “containing category” which is just a way to organize layers, but that cannot be requested directly.
Finally, a category can have a name allowing all the nested layers to be requested at once, which
sounds a lot like our layer groups, and seems to confirm that having a layer group with a
“layer in the root” was not intended by the original WMS spec (but it’s clearly demanded by
the WMS EO one).
Given this, my proposal for handling WMS EO would be the following.
First off, add a new field called “type” in layer group with the following possible values:
  • opaque: works as today, the user does not know there is structure inside
  • named category: works as today, but the group structure is exposed in the capabilities document
  • containing category: the group structure is exposed in the caps document, but the layer group
    is not given a name and thus cannot be used as a layer
  • earth observation group: in this case the structure is exposed in the caps document, but
    we also show a new “root layer” field allowing to configure the root layer.
A new option, “root layer” will be made available in the configuration, allowing the
WMS EO root layer.
The LayerGroup will have a new renderingLayers() method that will be used by code
to get the list of layers to be used for rendering.
In case of opaque and named category without root it will just return the layers,
in case of containing category it will throw a service exception, and in case
of earth observation group, it will return the root layer.
Seems to me this gives most of the benefit without getting users into too much confusion,
it also labels the EO specific usage quite clearly, hopefully people not knowing what
that is will stay away from it.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The general approach sounds reasonable to me. I would quibble a bit on the names though - I’d prefer not to have to explain what it means to request an opaque layergroup with transparency enabled :slight_smile:
How about:
  • Single: works as today, the user does not know there is structure inside
  • Group and Single: works as today, but the group structure is exposed in the capabilities document
  • Group Only: the group structure is exposed in the caps document, but the layer group
  • Earth Observation Group: in this case the structure is exposed in the caps document, but
On Mon, Dec 10, 2012 at 6:47 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
the WMS EO one).
WMS EO root layer.
Ing. Andrea Aime
@geowolf
Technical Lead
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
Geoserver-devel mailing list
On Mon, Dec 10, 2012 at 4:19 PM, David Winslow <dwinslow@anonymised.com> wrote:
He he
How about:
How about we call the second “Group” and the second “Container”?
Regardless, I believe we’ll have to explain the users the difference between them all…
Ing. Andrea Aime
@geowolf
Technical Lead
+0 - “Group” and “Container” doesn’t seem more or less clear than “Group and Single” and “Group Only” to me. The main thing IMHO is to avoid overloading the term ‘opaque.’ And we definitely will have to have some documentation regardless.
On Mon, Dec 10, 2012 at 11:26 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
He he
How about:
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Dec 10, 2012 at 5:28 PM, David Winslow <dwinslow@anonymised.com> wrote:
Yeah… what bother me is this thing of a group that is normally exposed as a single, but can be exposed as a group… ugh…
Imho we should try avoiding using group again in the names, since it’s already a layer group.
How about: single, named tree, container tree, eo tree?
Ing. Andrea Aime
@geowolf
Technical Lead
"Tree" to my mind definitely implies full nesting. But what about the
rules on content? A named tree obviously can contain a single. Can a
container tree include a named tree?
Is an EO tree just a root + container tree?
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
On Mon, Dec 10, 2012 at 9:08 PM, Phil Scadden <p.scadden@anonymised.com> wrote:
“Tree” to my mind definitely implies full nesting. But what about the
Nesting group layers is something we should work on in the future, and it’s indeed possible
in WMS, but not part of the WMS EO effort scope (neither is supporting the “container tree”
for that matter, but I’m trying to add at least the low effort extras for sake of generality)
Pretty much, yes
Ing. Andrea Aime
@geowolf
Technical Lead
