Hey folks,
I wanted to run some proposed refactoring of the ResourcePool class past everyone. Basically my goal is two-fold. The first and primary goal is to extend to the jdbcconfig module to allow for storing SLD contents along with configured style objects. It is really the last step to make the module able to store all catalog contents in the database.
The idea would be to make it possible to plug in a custom ResourcePool implementation via spring. The lookup mechanism is similar to how others work in that first we would look for an instance in the spring context, and if not found fall back to the default implementation.
A secondary goal is to allow for implementations to control how the various caches in ResourcePool are created. One thing I have been wanting to experiment with is the idea of distributed caches that GeoServers in a cluster could potentially share. This secondary goal is not an immediate one but I figured since i was mucking around in the vicinity i would make these changes as well.
All in all the changes are pretty straight forward, and mostly a pure refactoring with no behavioural changes.
https://github.com/jdeolive/geoserver/commit/2dd214507cd764486707ed93711f380ff4db0f71
Thoughts or opinions? Do people feel this is something proposal worthy? I should note that i was hoping to do this on 2.3.x.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
